PASSAT 3C TDI terugroep aktie VW!!
3errors
Zal natuurlijk niet in Nederland gaan gebeuren :angry: , maar wie weet...
Onderstaande van 'onze' Duitse tegenhanger geplukt.
Ich bin heute über folgende interessante Neuigkeit gestolpert, welche ich Euch auf keinen Fall vorenthalten möchte.
Volkswagen lässt in England alle anfälligen PPD Elemente mit einer Feldaktion (23H9) tauschen.
(Seit dem 01.10.2010 gibt es nämlich überarbeitete PPD Elemente!)
Hier ein Auszug aus dem Anschreiben.
... This is a brief précis of the VW UK Service Action 23H9 regarding Piezo pump injectors.
The repair instructions are contained in Technical Product Information (TPI) transaction number 2027647
This applies to 2.0TDI PD Golf, Passat, and Touran with PD Piezo Injectors
There are approximately 78,800 (model years 2006 – 2010) affected vehicles in the UK.
Owners will receive communications from Volkswagen UK on a phased basis.
The following vehicles with the engine codes listed are affected.
Passat 3C 2006-2008 with the BKP, BMA, BWV, BVE, BKP, BVE, BMA, BWV, BMR, and BUZ engines
Golf 5 2006-2009 with the BMN engine
Touran 2006-2010 with the BMN engine
Technical background
On some vehicles with the 2.0l TDI engine, deposits can settle on the Piezo pump injector elements because of dirty engine oil. This can lead to running problems. Not all vehicles are affected by this campaign! On the affected vehicles the Piezo pump injector elements must be checked and if necessary replaced. Please make sure that on the affected vehicle the check and repair of all open campaigns/measures are performed during the workshop visit.
Parts to be fitted as part of this campaign.
1x Campaign 23H9 sticker 000 010 006
1x Wiring loom adapter 03G 971 033 M
4x Adjustment screw WHT 000 530
5x M8x58 socket head bolt N 105 811 01
8x M6x88 socket head bolt 03G 103 385 A
4x Pump injectors
If the vehicle is listed in the system as not completed, check whether a campaign sticker with the entry "23H9 date/stamp" is attached in the spare wheel well area (next to data sticker):If the campaign sticker is attached, the campaign has already been performed. Make the entry “23H9 date/stamp” in the service schedule under “Space for workshop entries”.
If the campaign sticker with entry "23H9" is not fitted, carry out the work according to the repair instructions.
Identifying the potentially faulty injectors.
Remove cam cover and check the part number –see arrow- on the pump injector element. All pump injector elements with the part number 03G 130 073 D or 03G 130 073 M must be replaced. All other pump injector elements are correct and must not be replaced.
Ich war heute schon mal so nett und habe Autobild sowie das KBA informiert, mit der bitte um Klärung warum diese Feldaktion nicht auch für Deutschland gilt.
Zou mogelijk een hoop ergenis schelen bij de eigenaren :angel:
  • Antwoorden 430
  • Created
  • Laatste reactie
Hij geeft bij mij: 14.03.2013 - 23H9 - S-Piezo Pumpe Duse Elemente
Ik neem aan dat ik hiervoor in aanmerking kom. Heeft er iemand enig idee bij welke dealer ik het beste contact mee kan opnemen in de buurt van Apeldoorn? Kan iemand me ook vertellen of het verstandig is om het te laten doen ook als de auto op dit moment goed rijd.
(erg makkelijk zo'n forum)
Ik hoor graag van jullie
In de buurt van Apeldoorn, ga naar Autohaas Zutphen.. nee, niet naar Autohaas Apeldoorn.. ;)
Bedankt voor jullie hulp, ik ga morgen meteen contact opnemen met de dealer in Zutphen!
Ik zat met dezelfde vraag, de dealer vertelde me dat ik het beter nu gelijk kon doen met als reden dat het nu de actie is en het vergoed/betaald wordt. Als PON zich bedenkt of de actie over een half jaar ofzo komt te vervallen sta je met lege handen als je dan problemen krijgt (geen idee of dat zo werkt maar ik was overtuigd)...
Morgen is mijne aan de beurt, mis hem nu al want hij slaapt bij de dealer vannacht ;)
hoe zit da nu eigenlijk als de auto gechipt is , je komt bij de dealer en laat die verstuivers vervangen
de dealer gaat natuurlijk een update doen van de motor software als die beschikbaar is , en dan :shock:
... ben je je chiptuning kwijt
Wat in het ene land een terugroepactie kan zijn kan in een ander land een werkplaatsactie zijn of helemaal geen actie.
Wordt dit door de importeur bepaalt, in dit geval PON?
Dat weet ik niet 100% zeker maar heb wel een vermoeden dat het gaat in samenspraak met fabriek en de importeur. Je moet ook kijken naar het feit dat op het moment dat het bijvoorbeeld een terugroepactie zou worden voor in 1x heel europa dat de vraag naar verstuivers dan zo groot zou worden dat de onderdelen niet/slecht beschikbaar worden,en daar schiet niemand iets mee op.
Dealers doen NOOIT zomaar updates en bij het vervangen van de verstuivers komt er geen testkast aan te pas, als er volgens de procedure wordt gewerkt van de werkplaatsactie.
Er werd mij ook verteld (net zoals Black Devil zegt) dat dit er niet aan te pas komt.. alleen de verstuivers worden vervangen en met de software gebeurt helemaal niks... Ik wilde namelijk m'n extra pk'tjes ook graag behouden...
echt leuk om te horen dat jullie eindelijk kosteloos geholpen worden :) !!! Is wel een beetje aan de late kant imo, maar nu kunnen jullie allemaal met een gerust hart verder rijden zonder bang te zijn dat je op 123 stil kan vallen...
Zouden ze eindelijk door hebben dat hun 2liter imago een deuk genomen, teveel klachten oid? Of worden er zo weinig nieuwe modellen verkocht door een geschaad vertrouwen in vw ?
nu nog een terugroep actie voor de stuurslotmodule en het petje is af !
Ben vanochtend op weg naar Winterswijk even langs Autohaas Zutphen gereden, zeer prettig geholpen daar.
Heb nu een afspraak voor 30 januari, klepdeksel eraf, wanneer de nummers van verstuivers voldoen aan de vervang criteria worden ze meteen vervangen.
Ben benieuwd!
Heb vandaag ook een afspraak gemaakt voor de 31ste in Zutphen.. Ben benieuwd, kreeg te horen dat als het de foute verstuivers waren dat ze zouden vervangen worden, zo niet, zouden ze erin blijven.. Maar neem aan dat het de foute zijn gezien ik in aanmerking kwam? We gaan het zien..
Auto net terug, alles nieuw erin, had dus de foute erin zitten.
Merk je verschil in het rijden? Ik heb denk ik ook 4 foute erin, deze worden volgende week maandag mij bij vervangen.
7 of 8 feb ga ik naar de dealer in Hengelo. Ook deze waren op de hoogte en zonder tegensputteren ;-)
Huiskes-Kokkeler?
Da's mooi... want dan zijn ze op de hoogte. Ik zal ook eens een belletje plegen.
De mijne had al eens een foutmelding op 1 PD volgens VAGcom.
En anders ga ik de grens over.. Otto Richelman uit Bad-Bentheim.
14.01.13 23H9 S-Piezo Pumpe Düse Elemente
(nieuw hier... al wel een tijdje meegelezen...)
De mijne (BMR) liep al een tijd te klieren met slechte starts, als het koud was, en hij een tijdje niet gedraaid had.
Ondertussen de meeste opties al geprobeerd, alles nagemeten/uitgelezen... 2 verstuivers bleken enigszins af te wijken, maar nog wel binnen de marge te zitten.
Nu ben ik gisteren gebeld, om 'm weer heen te brengen (naar garage) voor deze actie... Uiteraard was dit het proberen waard.
Op kosten van VW 4 nieuwe verstuivers laten plaatsen + kabelboom.
Vanmiddag de auto weer opgehaald. Toen ik 'm startte klonk hij gelijk beter. Voorheen altijd wat rauw, en wat ratelend, dat was nu helemaal weg...
Heb nu goeie hoop, dat het startprobleem ook verleden tijd is... Morgenochtend maar es ff testen... :wink:
Groet,
Ronald
