PASSAT 3C TDI terugroep aktie VW!!
3errors
Zal natuurlijk niet in Nederland gaan gebeuren :angry: , maar wie weet...
Onderstaande van 'onze' Duitse tegenhanger geplukt.
Ich bin heute über folgende interessante Neuigkeit gestolpert, welche ich Euch auf keinen Fall vorenthalten möchte.
Volkswagen lässt in England alle anfälligen PPD Elemente mit einer Feldaktion (23H9) tauschen.
(Seit dem 01.10.2010 gibt es nämlich überarbeitete PPD Elemente!)
Hier ein Auszug aus dem Anschreiben.
... This is a brief précis of the VW UK Service Action 23H9 regarding Piezo pump injectors.
The repair instructions are contained in Technical Product Information (TPI) transaction number 2027647
This applies to 2.0TDI PD Golf, Passat, and Touran with PD Piezo Injectors
There are approximately 78,800 (model years 2006 – 2010) affected vehicles in the UK.
Owners will receive communications from Volkswagen UK on a phased basis.
The following vehicles with the engine codes listed are affected.
Passat 3C 2006-2008 with the BKP, BMA, BWV, BVE, BKP, BVE, BMA, BWV, BMR, and BUZ engines
Golf 5 2006-2009 with the BMN engine
Touran 2006-2010 with the BMN engine
Technical background
On some vehicles with the 2.0l TDI engine, deposits can settle on the Piezo pump injector elements because of dirty engine oil. This can lead to running problems. Not all vehicles are affected by this campaign! On the affected vehicles the Piezo pump injector elements must be checked and if necessary replaced. Please make sure that on the affected vehicle the check and repair of all open campaigns/measures are performed during the workshop visit.
Parts to be fitted as part of this campaign.
1x Campaign 23H9 sticker 000 010 006
1x Wiring loom adapter 03G 971 033 M
4x Adjustment screw WHT 000 530
5x M8x58 socket head bolt N 105 811 01
8x M6x88 socket head bolt 03G 103 385 A
4x Pump injectors
If the vehicle is listed in the system as not completed, check whether a campaign sticker with the entry "23H9 date/stamp" is attached in the spare wheel well area (next to data sticker):If the campaign sticker is attached, the campaign has already been performed. Make the entry “23H9 date/stamp” in the service schedule under “Space for workshop entries”.
If the campaign sticker with entry "23H9" is not fitted, carry out the work according to the repair instructions.
Identifying the potentially faulty injectors.
Remove cam cover and check the part number –see arrow- on the pump injector element. All pump injector elements with the part number 03G 130 073 D or 03G 130 073 M must be replaced. All other pump injector elements are correct and must not be replaced.
Ich war heute schon mal so nett und habe Autobild sowie das KBA informiert, mit der bitte um Klärung warum diese Feldaktion nicht auch für Deutschland gilt.
Zou mogelijk een hoop ergenis schelen bij de eigenaren :angel:
  • Antwoorden 430
  • Created
  • Laatste reactie
Was vanochtend om 8 uur op afspraak bij Autohaas Zutphen, 10.15 u stond de Passat weer buiten met 4 nieuwe verstuivers en kabelboom, PD 2e cilinder welke 2 jaar geleden was vervangen had ook nog een nummer uit de oude serie. Vandaar 4 nieuwe. Motor is "helaas" toch iets feller geworden, waarschijnlijk door ander inspuitbeeld. Zal zien of ie straks ook minder rookt bij doortrekken en iets zuiniger is.
Goede service bij Autohaas, vertrouwen in VW voorlopig weer hersteld. :thumb:
Top service, dat je 'm zo snel terug. :thumb:
Heb je al gemerkt dat die stukken stiller is met koude motor?
Nee, hij is met 90 graden naar binnen gegaan en 2 uur later met 80 graden naar buiten gereden :)
2 uurtjes!! Wij moetem hem 2 dagen missen. Maar goed, ik ben allang blij dat VW deze ze doet.
Ik heb het idee dat mijn auto naar het vervangen van de verstuiver heel lichtjes stottert/trilling bij stationar lopen als hij warm is. Bij koud motor heb ik dit niet. En ja dit is begonnen nadat VW verstuiver heeft vervangen
Misschien zit het ''tussen de oren'' , als het blijft terugkomen zou ik als ik jou was de dealer opbellen en vertellen wat er mis is.
Die van mij had gister bij een koude start een lichte trilling (ik wou kijken of ik verschil merkte, dan let je dus veel meer op en kan je rare dingen horen/voelen), de eerste paar seconden, toen niks meer, dus kan ook ''tussen de oren'' zitten he..
Nou of het tussen de oren zit weet ik bijna zeker van niet. 2 maanden geleden was er ook een verstuiver vervangen en toen had ik dit niet.. Idd ik ga nog een paar dagen er mee rond rijden. Mocht het nog steeds zo zijn dan gaan we verder zoeken.
Moet helaas nog een dagje langer wachten, kabelboompje was niet met de bestelling meegekomen. Ze boden wel heel netjes hun excuses aan. Ach nou ja, of ik hem nou 2 dagen moet missen of dat maakt me dan ook niet zoveel meer uit.
Je jeepje rijd toch ook comfortabel, of nog lang niet zo lekker als de Passat? :mrgreen:
Het rijdt leuk en anders maar comfortabel kun je het absoluut niet noemen. Tenminste niet als je een Passat gewend bent :mrgreen:
Wat een toptopic!
Vandaag afspraak gemaakt voor vrijdag. Gevraagd aan dealer hoe het zit met de kosten die ik (bij hen) in 2010 gemaakt heb voor het vervangen van een verstuivert. Hij zou dit voorleggen bij de importeur en mij dit vrijdag laten weten.. Werd ik vanmiddag al gebeld en jullie raden het al..
Volgens de dealer heb ik recht op de centen die ik toen bij hen heb afgetikt.. Het zal mij benieuwen wanneer ik het gestort krijg...
Wat een toptopic!
Sow! Dat is top nieuws!
Merken jullie overigens ook dat hij zuiniger is? Valt mij echt op!
Nog niks van gemerkt.. hoeveel zuiniger is die geworden? Kan ook aan het weer liggen he, het was vorig week -7C ongeveer en nu 5-10C, dat is een verschil van 12 minstens.
iet zuiniger, feller en ik denk ook iets stiller. Maar nogmaals wat ik eerder schreef...misschien is dat wat ik wil zien haha.
Vanochtend koude start, net als altijd prima, lijkt koud ietsjes minder te "nagelen". Heb vandaag 300 km gereden en reed gemiddeld 1:19 is zuiniger dan normaal, maar is te kort om er iets zinnigs over te zeggen. Bij flink doortrekken rookt ie als vanouds.
ik krijg het idee dat bij flink optrekken wat minder roet te zien is. Koude start gaat ook lekker idd. wat zou er nou anders zijn aan deze nieuwe verstuivers?
Ik merk geen verschil tov de oude verstuivers. Wel in mijn hoofd dat ik er een beter gevoel over heb.
Ben ook wel benieuwd wat er anders aan zou zijn idd
1:19 heb ik nog nooit gehaald gemiddeld. (7.1 op 100) ( maar daar is vast een ander topic voor :wink: )
met name "wat er aan veranderd is"en dan ook graag "gaan deze WEL lang mee?" en belangrijkste vraag, waar wij geen antwoord op gaan krijgen: "wat heeft PON doen besluiten om nu wel kostenloos de verstuivers om te wisselen". Ik snap gewoon niet dat het zo lang moest duren voor er mensen coulant geholpen werd.
