JoVos Geplaatst 5 november, 2012 Rapporteer Share Geplaatst 5 november, 2012 Heb gisteren een scan gedaan en zaten wat adressen bij die 'Cannot be reached' aangaven. Iemand een idee hoe ik deze wegkrijg of dat ze al dan niet kwaad kunnen? Address 01: Engine Labels: 03G-906-016-BKC.lbl Part No SW: 03G 906 021 DP HW: 028 101 274 2 Component: R4 1,9L EDC G000SG 7870 Revision: --H01--- Serial number: VWZCZ000000000 Coding: 0000071 Shop #: WSC 00028 028 00001 VCID: 70EBD4F31863 No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q Component: ESP 440 C2 H015 0003 Revision: H015 Serial number: 0658214692 Coding: 0029953 Shop #: WSC 00028 028 00001 VCID: 306B14F3D8E3 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Cannot be reached ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl Part No SW: 3C0 937 049 H HW: 3C0 937 049 H Component: Bordnetz-SG H37 1301 Revision: 00H37000 Serial number: 00000003540289 Coding: F0880F0700041A00280000000F0000000009FB4F5C0000 Shop #: WSC 12345 123 67890 VCID: 2E570A8BC2D7 Subsystem 1 - Part No: 3C1 955 119 Component: Wischer VW461 012 0503 Coding: 00065493 Shop #: WSC 12345 Subsystem 2 - Part No: 1K0 955 559 T Component: RegenLichtSens 011 1110 Coding: 00471077 Shop #: WSC 12345 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 3C0-909-605.lbl Part No SW: 3C0 909 605 F HW: 3C0 909 605 F Component: 01 AIRBAG VW8 029 2421 Revision: 08029000 Serial number: 0039USJCM2FB Coding: 0012337 Shop #: WSC 00028 028 00001 VCID: 295DF997FB39 1 Fault Found: 01217 - Can't Decode, CODE File Not Loaded! 001 - Can't Decode, CODE File Not Loaded! - MIL ON ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl Part No SW: 3C0 953 549 A HW: 3C0 953 549 A Component: Lenks‰ulenmodul 005 0010 Revision: 00005000 Serial number: 3C5953507C Coding: 0000013 Shop #: WSC 00028 028 00001 VCID: 2A5F069BFE3F No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Cannot be reached ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530.lbl Part No SW: 3C0 907 530 C HW: 3C0 907 951 A Component: Gateway 007 0040 Revision: 00007000 Serial number: 0700C059190152 Coding: 3DFDAC44C21002 Shop #: WSC 00028 028 00001 VCID: 214DE1B78309 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 K HW: 3C0 959 433 K Component: IMMO 038 0367 Revision: 00038000 Serial number: VWZCZ000000000 Shop #: WSC 01503 202 93189 VCID: 326F1EFBD6EF Part No: 3C0 905 861 J Component: ELV 029 0380 3C0905861J ELV 029 0380 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl Part No: 1K0 959 701 K Component: Tuer-SG 024 2365 Coding: 0000181 Shop #: WSC 00028 028 00001 VCID: 366722EB3A87 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x.lbl Part No: 1K1 909 144 J Component: EPS_ZFLS Kl.5 D04 1606 Shop #: WSC 00000 000 00000 VCID: 326F1EFBD6EF No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 K HW: 3C0 959 433 K Component: KSG PQ46 ELV 038 0455 Revision: 00038000 Serial number: VWZCZ000000000 Coding: 18910A0801860E7F38021F1FF0084F0B603C80 Shop #: WSC 12345 123 12345 VCID: 326F1EFBD6EF Component: Sounder n.mounted Component: NGS n.mounted Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl Part No: 1K0 959 702 K Component: Tuer-SG 024 2365 Coding: 0000180 Shop #: WSC 00028 028 00001 VCID: 37792FEF3D8D No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3C0-907-801-53.lbl Part No SW: 3C0 907 801 B HW: 3C0 907 801 B Component: EPB VC8HC001 013 0001 Revision: 013 Coding: 0000012 Shop #: WSC 131071 1023 2097151 VCID: 214DE1B78309 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl Part No: 1K0 959 703 F Component: Tuer-SG 021 2432 Coding: 0000144 Shop #: WSC 00028 028 00001 VCID: 33611BFF29F5 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer Labels: 1K0-907-383-MY7.lbl Part No SW: 1K0 907 383 HW: 1K0 907 383 Component: ANHAENGERELEKTR 001 0020 Coding: 0000001 Shop #: WSC 00028 028 00001 VCID: EADF469BBEBF No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl Part No: 1K0 959 704 F Component: Tuer-SG 021 2432 Coding: 0000144 Shop #: WSC 00028 028 00001 VCID: 346318E32CFB No fault code found. ------------------------------------------------------------------------------- Address 7D: Aux. Heat Labels: 1K0-963-235.lbl Part No SW: 1K0 963 235 E HW: 1K0 963 235 E Component: PTC-Element 0404 Revision: 00800000 Serial number: Shop #: WSC 00000 000 00000 VCID: 2D550D87CFD1 No fault code found. Link naar reactie Delen op andere sites More sharing options...
0 Robl Geplaatst 5 november, 2012 Rapporteer Share Geplaatst 5 november, 2012 Een oorzaak heb ik 123 niet paraat. Het lijkt wel dat jij of de vorige eigenaar behoorlijk aan het coderen is geweest. Welk modeljaar en motorcode heb je? Link naar reactie Delen op andere sites More sharing options...
0 JoVos Geplaatst 6 november, 2012 Auteur Rapporteer Share Geplaatst 6 november, 2012 Ik in elk geval niet want heb schrik dat ik iets verkeerd zou doen Zal morgen eens kijken nr motorcode want weet ik niet direct uit mijn hoofd. Bouwjaar is in elk geval 10/2005 Link naar reactie Delen op andere sites More sharing options...
0 Robl Geplaatst 6 november, 2012 Rapporteer Share Geplaatst 6 november, 2012 Ja is goed. Bij jou geen toegang tot: - climatronic (klopt het dat je automatische airco hebt?) - instruments - navigatie - radio (wat heb je nu in zitten?) Hm misschien dat de deskundigen nu even moeten nadenken. Kan dit een gatewayprobleem zijn? Link naar reactie Delen op andere sites More sharing options...
0 Lucas Geplaatst 6 november, 2012 Rapporteer Share Geplaatst 6 november, 2012 Je can-gateway is te oud, deze kan niet communiceren met de witte teller en golf6 klima paneel. Link naar reactie Delen op andere sites More sharing options...
0 Tikra Geplaatst 6 november, 2012 Rapporteer Share Geplaatst 6 november, 2012 Onze passat 2.tdi is van 09/2005 motorcode BMP heb je een 1.9 of 2.o Link naar reactie Delen op andere sites More sharing options...
0 Lucas Geplaatst 6 november, 2012 Rapporteer Share Geplaatst 6 november, 2012 Je motorcode is BKC Link naar reactie Delen op andere sites More sharing options...
0 R-line Geplaatst 6 november, 2012 Rapporteer Share Geplaatst 6 november, 2012 Als je radio/navigatie niet aan staat tijdens de scan is hij niet bereikbaar en krijg je dus die melding. Instruments geef bij mij ook wel eens de melding en de volgende keer is hij wel uitleesbaar ? Je software kan ook te oud zijn en zodoende niet alles herkennen. Link naar reactie Delen op andere sites More sharing options...
0 Robl Geplaatst 6 november, 2012 Rapporteer Share Geplaatst 6 november, 2012 Je motorcode is BKC Hoe weet jij dat Link naar reactie Delen op andere sites More sharing options...
0 Ozzy Geplaatst 6 november, 2012 Rapporteer Share Geplaatst 6 november, 2012 Je motorcode is BKC Hoe weet jij dat Doe is alt+f en typ bkc , als het goed is zie je dan in de log bkc staan Link naar reactie Delen op andere sites More sharing options...
0 Lucas Geplaatst 6 november, 2012 Rapporteer Share Geplaatst 6 november, 2012 Je motorcode is BKC Hoe weet jij dat Ik heb een glazen bol Link naar reactie Delen op andere sites More sharing options...
0 Robl Geplaatst 6 november, 2012 Rapporteer Share Geplaatst 6 november, 2012 Je motorcode is BKC Hoe weet jij dat Doe is alt+f en typ bkc , als het goed is zie je dan in de log bkc staan Je zit me in de maling te nemen alt+f ken ik niet, ctl+f gebruik ik wel vaak De naam van de labelfile eindigt welliswaar op "BKC" maar die labelfile gebruikt VCDS bij mijn "BXE" ook Link naar reactie Delen op andere sites More sharing options...
0 Ozzy Geplaatst 6 november, 2012 Rapporteer Share Geplaatst 6 november, 2012 Oeps.. Link naar reactie Delen op andere sites More sharing options...
0 JoVos Geplaatst 6 november, 2012 Auteur Rapporteer Share Geplaatst 6 november, 2012 Motorcode is idd BKC, daarstraks nagekeken En als men gateway idd verouderd is, hoe kan ik dit dan oplossen? Nieuw boordnet steken? Link naar reactie Delen op andere sites More sharing options...
0 Robl Geplaatst 7 november, 2012 Rapporteer Share Geplaatst 7 november, 2012 gateway en boordnet zijn 2 verschillende dingen http://www.my-gti.com/2296 Link naar reactie Delen op andere sites More sharing options...
0 JoVos Geplaatst 7 november, 2012 Auteur Rapporteer Share Geplaatst 7 november, 2012 Wist ik niet daarmee dat ik het vroeg dus bedankt, weer iets bijgeleerd Door welke moet ik deze dan vervangen? Link naar reactie Delen op andere sites More sharing options...
0 Robl Geplaatst 7 november, 2012 Rapporteer Share Geplaatst 7 november, 2012 Dat kun je proberen. Er zijn verschillende versies in omloop. Misschien moet je even googelen op dit onderwerp om zekerheid over de versie te krijgen. Zo'n apparaat kun je vaak via de sloper of ebay/marktplaats wel vinden. In BE zitten ook een paar handige forumleden die (ook op elektronisch gebied) veel VW-ervaring hebben. Als je zorgt dat die jou aardig vinden willen ze je vast helpen Link naar reactie Delen op andere sites More sharing options...
0 JoVos Geplaatst 11 november, 2012 Auteur Rapporteer Share Geplaatst 11 november, 2012 Dat kun je proberen.Er zijn verschillende versies in omloop. Misschien moet je even googelen op dit onderwerp om zekerheid over de versie te krijgen. Zo'n apparaat kun je vaak via de sloper of ebay/marktplaats wel vinden. In BE zitten ook een paar handige forumleden die (ook op elektronisch gebied) veel VW-ervaring hebben. Als je zorgt dat die jou aardig vinden willen ze je vast helpen Ga waarschijnlijk nieuwe gateway moeten aanschaffen door aankoop RNS dus dan zal het probleem wel verholpen zijn Toch bedankt voor de hulp Link naar reactie Delen op andere sites More sharing options...
0 JoVos Geplaatst 12 november, 2012 Auteur Rapporteer Share Geplaatst 12 november, 2012 Heb vandaag een nieuwe gateway aangeschaft namelijk deze: 3C0907530Q (dus heb het direct goed gedaan ) Bij nieuwe scan zijn de meeste foutcodes opgelost maar toch nog een paar onbereikbare adressen. Heb nu ook plots foutmelding in adres 8 (clima stond gewoon aan) en 17 (waar ik met vorige gateway niet eens in kon) die ik niet wegkrijg. Iemand idee wat nu het probleem nog kan zijn? Resultaat van scan met nieuwe gateway: Address 01: Engine Labels: 03G-906-016-BKC.lbl Part No SW: 03G 906 021 DP HW: 028 101 274 2 Component: R4 1,9L EDC G000SG 7870 Revision: --H01--- Serial number: VWZCZ000000000 Coding: 0000071 Shop #: WSC 00028 028 00001 VCID: 70EBD4F31863 No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q Component: ESP 440 C2 H015 0003 Revision: H015 Serial number: 0658214692 Coding: 0029953 Shop #: WSC 00028 028 00001 VCID: 306B14F3D8E3 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb Part No SW: 5K0 907 044 DT HW: 5K0 907 044 DT Component: Climatronic H17 1010 Revision: 00001003 Coding: 0000000002 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_Climatronic A01010 ROD: EV_Climatronic_VW46.rod VCID: 800B0433A8C3 1 Fault Found: 9479189 - Can't Decode, CODE File Not Loaded! UBFEC5DA 15 [009] - Can't Decode, CODE File Not Loaded! Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 33 Mileage: 149456 km Date: 2031.14.29 Time: 19:57:04 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl Part No SW: 3C0 937 049 H HW: 3C0 937 049 H Component: Bordnetz-SG H37 1301 Revision: 00H37000 Serial number: 00000003540289 Coding: F0880F0700041A00280000000F0000000009FB4F5C0000 Shop #: WSC 12345 123 67890 VCID: 2E570A8BC2D7 Subsystem 1 - Part No: 3C1 955 119 Component: Wischer VW461 012 0503 Coding: 00065493 Shop #: WSC 12345 Subsystem 2 - Part No: 1K0 955 559 T Component: RegenLichtSens 011 1110 Coding: 00471077 Shop #: WSC 12345 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags Labels: 3C0-909-605.lbl Part No SW: 3C0 909 605 F HW: 3C0 909 605 F Component: 01 AIRBAG VW8 029 2421 Revision: 08029000 Serial number: 0039USJCM2FB Coding: 0012337 Shop #: WSC 00028 028 00001 VCID: 295DF997FB39 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl Part No SW: 3C0 953 549 A HW: 3C0 953 549 A Component: Lenks‰ulenmodul 005 0010 Revision: 00005000 Serial number: 3C5953507C Coding: 0000013 Shop #: WSC 00028 028 00001 VCID: 2A5F069BFE3F No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb Part No SW: 3C0 920 861 C HW: 3C0 920 861 C Component: KOMBI H02 0206 Serial number: 00000000000000 Coding: 160D00 Shop #: WSC 12345 123 56789 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040 ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod VCID: 2341EBBF9915 1 Fault Found: 49497 - Can't Decode, CODE File Not Loaded! UBFEC645 00 [009] - Can't Decode, CODE File Not Loaded! Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 33 Mileage: 149456 km Date: 2031.14.29 Time: 19:57:50 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530.lbl Part No SW: 3C0 907 530 Q HW: 3C0 907 951 Component: J533 Gateway H13 0171 Revision: H13 Serial number: 3520P09B200A07 Coding: F9A07F56400202001002 Shop #: WSC 05314 000 00000 VCID: 2F69178FC5DD No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 K HW: 3C0 959 433 K Component: IMMO 038 0367 Revision: 00038000 Serial number: VWZCZ000000000 Shop #: WSC 01503 202 93189 VCID: 326F1EFBD6EF Part No: 3C0 905 861 J Component: ELV 029 0380 3C0905861J ELV 029 0380 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl Part No: 1K0 959 701 K Component: Tuer-SG 024 2365 Coding: 0000181 Shop #: WSC 00028 028 00001 VCID: 366722EB3A87 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x.lbl Part No: 1K1 909 144 J Component: EPS_ZFLS Kl.5 D04 1606 Shop #: WSC 00000 000 00000 VCID: 326F1EFBD6EF No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 K HW: 3C0 959 433 K Component: KSG PQ46 ELV 038 0455 Revision: 00038000 Serial number: VWZCZ000000000 Coding: 18910A0801860E7F38021F1FF0084F0B603C80 Shop #: WSC 12345 123 12345 VCID: 326F1EFBD6EF Component: Sounder n.mounted Component: NGS n.mounted Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl Part No: 1K0 959 702 K Component: Tuer-SG 024 2365 Coding: 0000180 Shop #: WSC 00028 028 00001 VCID: 37792FEF3D8D No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3C0-907-801-53.lbl Part No SW: 3C0 907 801 B HW: 3C0 907 801 B Component: EPB VC8HC001 013 0001 Revision: 013 Coding: 0000012 Shop #: WSC 131071 1023 2097151 VCID: 214DE1B78309 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl Part No: 1K0 959 703 F Component: Tuer-SG 021 2432 Coding: 0000144 Shop #: WSC 00028 028 00001 VCID: 33611BFF29F5 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer Labels: 1K0-907-383-MY7.lbl Part No SW: 1K0 907 383 HW: 1K0 907 383 Component: ANHAENGERELEKTR 001 0020 Coding: 0000001 Shop #: WSC 00028 028 00001 VCID: EADF469BBEBF No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl Part No: 1K0 959 704 F Component: Tuer-SG 021 2432 Coding: 0000144 Shop #: WSC 00028 028 00001 VCID: 346318E32CFB No fault code found. ------------------------------------------------------------------------------- Address 7D: Aux. Heat Labels: 1K0-963-235.lbl Part No SW: 1K0 963 235 E HW: 1K0 963 235 E Component: PTC-Element 0404 Revision: 00800000 Serial number: Shop #: WSC 00000 000 00000 VCID: 2D550D87CFD1 No fault code found. End --------------------------------------------------------------------- Link naar reactie Delen op andere sites More sharing options...
0 dreke Geplaatst 13 november, 2012 Rapporteer Share Geplaatst 13 november, 2012 Adres 10 is aangevinkt in de gateway, en je hebt geen PDC (of een oude versie dan moet je ardes 76 aanvinken) Radio is aangevinkt en er zit geen OEM radio in... Welke Versie VCDS gebruik je? Blijkbaar kent die je airco en instrumenten niet (geen labelfiles). grtz, dre Link naar reactie Delen op andere sites More sharing options...
0 JoVos Geplaatst 14 november, 2012 Auteur Rapporteer Share Geplaatst 14 november, 2012 Probleem van de PDC is al opgelost. Heb aftermarket PDC dus niet nodig om aan t melden Probleem van OEM radio is zondag van de baan, dan heb ik men RNS Moet ik hiervoor nog iets speciaal aanvinken buiten navigatie zodat batterij niet leegloopt? Welke versie moet ik morgen eens bekijken maar waarschijnlijk verouderde Wou deze morgen needle sweep instellen maar gaf error aan dus zal wel daar aan liggen Link naar reactie Delen op andere sites More sharing options...
JoVos
Coding: 0000071
VCID: 70EBD4F31863
Coding: 0029953
VCID: 306B14F3D8E3
Cannot be reached
VCID: 2E570A8BC2D7
Coding: 00065493
Shop #: WSC 12345
Coding: 00471077
Shop #: WSC 12345
Coding: 0012337
VCID: 295DF997FB39
1 Fault Found:
Coding: 0000013
VCID: 2A5F069BFE3F
Cannot be reached
VCID: 214DE1B78309
VCID: 326F1EFBD6EF
Cannot be reached
Coding: 0000181
VCID: 366722EB3A87
VCID: 326F1EFBD6EF
VCID: 326F1EFBD6EF
Coding: 0000180
VCID: 37792FEF3D8D
Revision: 013
Coding: 0000012
VCID: 214DE1B78309
Address 56: Radio
Cannot be reached
Coding: 0000144
VCID: 33611BFF29F5
Coding: 0000001
VCID: EADF469BBEBF
Coding: 0000144
VCID: 346318E32CFB
VCID: 2D550D87CFD1
20 antwoorden op deze vraag
