klap functie spiegel met AB in combinatie met laatste versie VCDS
Diver
Aangezien er meerdere waren die de functie niet konden vinden in de nieuwere versie van VCDS heb ik Rosstech een mail gestuurd. en jullie belooft het te posten. Hier de mail wisseling.
1:
Hello can you help me out with this problem, previous it was possible with older versions of VCDS to  program the folding mirror so they work by pushing the lock button on the remote ( car key ) but now I can`t find it anymore, are there chances in the program, ore is it renamed.
1.Select [42-Door Elec, Driver]
2.Klik [security Access - 16]
3.enter security code "04354" and click op "Do it!"
4.Back in the previous menu , click  [Adaptation -10]
5.Selectthe next channel: (9)-System_Parameter_0-System Parameter Byte8 ( it should be a bit at the bottom )
6.now you See the value is 90. You have 2 options : 1.95 – on remote keep  lock button pressed to fold mirrors and unfold with motor on.
2.99 -  Keep  lock button pressed to fold mirror, and unfold by opening the door.
7.Klik op "Do it!" than  "Yes"
8.than you get the massage code accepted click ok
9.Now you are done...
Monday,19,March,2018,18:48:01:35994
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
   Part No SW: 3C0 959 701 A    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0329
   Revision: 12101005    Serial number: 0001530550
   Coding: 0011FF
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_DCU42BroseDriveSide A03004
   ROD: EV_DCU42BroseDriveSide_VW32.rod
   VCID: 26427CA5596B977442-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388__TSG-HL  005 1114
   Serial number: 00000000750402
   Coding: 0000D0
No fault code found.
Thanks in advance
Best Regards Jan Stoof
aangepast door Diver
Antwoord:
Hi Jan,
Because ASAM/ODX Data changes over the years that channel may be renamed, rather than missing entirely.  It would be best to post this question in the Tweaks sub-forum with a complete scan and Adp function map
http://forums.ross-tech.com/
.. but you can send that info in reply so we can try to determine if the channel still exists.
This is a bad example because my Mom's Tiguan does NOT have folding mirrors but the #42 Adp map would contain a list all of the channels like this:
http://forums.ross-tech.com/showthread.php?13093-2017-Tiguan-Limited-(Old-Mk6-body-style)-2-0T-CCTA&p=118996&viewfull=1#post118996
Mapping is explained on the following page if you aren't familiar with the function:
http://www.ross-tech.com/vcds/tour/controller-channels-map.php
Best Regards,
Dana
Vraag:
Hi Dana
 where can I find the Adp function map for my 42 door electric driver, ore how do I print the text.
 Jan
Atw:
Hi Jan,
You would firstly need to create a map with the key on using these steps:
[Applications]
[Controller Channels Map]
Address: 42
Login or SA code: 04354
Function: Adaptation
Output: CSV File
[start]
The resulting CSV file will be located in the Logs folder.  You can open it with Notepad in plain text if you don't have Excel or similar spreadsheet software installed.
If you paste it to our forum it must be in plain text so I would use Notepad to open it.
Regards,
Dana
P.S. What I think you are going to find is ENG109297-System-Parameter Block -and- ENG109279-System_Parameter_0 both contain the Byte 8 value of 90 that would have previously been shown in ENG109279-ENG99426-System_Parameter_0-System Parameter Byte8.
If that's the case the modification could be completed in ENG109279 -or-
ENG109297 as long as you change the proper position.
Laten we de rest van de discussie in een ander topic houden zodat dit hier wat overzichtelijk blijft en dat het later ook bruikbaar is ipv te moeten zoeken tussen allerlei reacties.
Klopt ben ik het mee eens wulfke..
Ben al een tijd aan het zoeken hoe en wat met de klapspiegels.
Vindt ik het enige min punt dan de auto dat ze niet automatisch inklappen.
Maar dat het handmatig moet gebeuren.
Begrijp ik maar er zijn al genoeg lopende topics over klapspiegels waar je verder op in kan gaan. Dit topic gaat over het feit dat de nieuwe VCDS de functie niet meer laat activeren en dat Jan samen met Ross tech aan het kijken is voor een oplossing.
Ik heb het gevonden hoe het moet en waar je de wijziging moet aanbrengen bij de nieuwe VCDS.
Je gaat via adaption naar
ENG109279-system_parameter_0
Daar zie je dan bij stores value een hele reeks cijfers en letters.
Het 9de koppel is de instelling van de spiegels.
Ik had hiervoor de waarde 99 erin staan
(Spiegels uitklappen bij openen van de deur)
En nu heb ik deze aangepast naar 95 en nu klappen de spiegels uit bij het contact aanzetten.
Ik heb mijn Adaption map log op het forum gezet bij Rosstech, nu kijken wat de reacties zijn. hier onder de log.
;SW:3C0-959-701-A   HW:3C0-959-793-A ---  Door Elect, Driver --- SA: 04354
;Component:TUER-SG FT    002 0329, Coding:0011FF
;EV_DCU42BroseDriveSide,A03004,EV_DCU42BroseDriveSide_VW32.rod
;Thursday,31,May,2018,17:39:08:35994
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
;VCID: 26427CA5596B97747D-8072
ENG106031-ENG103506-ECU ID2 PartNumber HW SW-Byte 1,1 ,22
ENG106031-ENG99970-ECU ID2 PartNumber HW SW-Byte 10,G ,22
ENG106031-ENG103845-ECU ID2 PartNumber HW SW-Byte 11,  ,22
ENG106031-ENG103008-ECU ID2 PartNumber HW SW-Byte 12,0 ,22
ENG106031-ENG100040-ECU ID2 PartNumber HW SW-Byte 13,0 ,22
ENG106031-ENG101630-ECU ID2 PartNumber HW SW-Byte 14,1 ,22
ENG106031-ENG99906-ECU ID2 PartNumber HW SW-Byte 15,C ,22
ENG106031-ENG99415-ECU ID2 PartNumber HW SW-Byte 16,  ,22
ENG106031-ENG101004-ECU ID2 PartNumber HW SW-Byte 17,  ,22
ENG106031-ENG100194-ECU ID2 PartNumber HW SW-Byte 18,  ,22
ENG106031-ENG102302-ECU ID2 PartNumber HW SW-Byte 19,  ,22
ENG106031-ENG100432-ECU ID2 PartNumber HW SW-Byte 2,K ,22
ENG106031-ENG102337-ECU ID2 PartNumber HW SW-Byte 20,  ,22
ENG106031-ENG100802-ECU ID2 PartNumber HW SW-Byte 21,  ,22
ENG106031-ENG101604-ECU ID2 PartNumber HW SW-Byte 22,  ,22
ENG106031-ENG103171-ECU ID2 PartNumber HW SW-Byte 3,0 ,22
ENG106031-ENG99780-ECU ID2 PartNumber HW SW-Byte 4,9 ,22
ENG106031-ENG101635-ECU ID2 PartNumber HW SW-Byte 5,5 ,22
ENG106031-ENG100290-ECU ID2 PartNumber HW SW-Byte 6,9 ,22
ENG106031-ENG101242-ECU ID2 PartNumber HW SW-Byte 7,7 ,22
ENG106031-ENG101974-ECU ID2 PartNumber HW SW-Byte 8,9 ,22
ENG106031-ENG100834-ECU ID2 PartNumber HW SW-Byte 9,5 ,22
ENG106032-ENG103506-ECU ID2 PartNumber VW SW ID-Byte 1,1 ,20
ENG106032-ENG99970-ECU ID2 PartNumber VW SW ID-Byte 10,P ,20
ENG106032-ENG103845-ECU ID2 PartNumber VW SW ID-Byte 11,  ,20
ENG106032-ENG103008-ECU ID2 PartNumber VW SW ID-Byte 12,L ,20
ENG106032-ENG100040-ECU ID2 PartNumber VW SW ID-Byte 13,1 ,20
ENG106032-ENG101630-ECU ID2 PartNumber VW SW ID-Byte 14,5 ,20
ENG106032-ENG99906-ECU ID2 PartNumber VW SW ID-Byte 15,9 ,20
ENG106032-ENG99415-ECU ID2 PartNumber VW SW ID-Byte 16,± ,20
ENG106032-ENG101004-ECU ID2 PartNumber VW SW ID-Byte 17,1 ,20
ENG106032-ENG100194-ECU ID2 PartNumber VW SW ID-Byte 18,1 ,20
ENG106032-ENG102302-ECU ID2 PartNumber VW SW ID-Byte 19,4 ,20
ENG106032-ENG100432-ECU ID2 PartNumber VW SW ID-Byte 2,K ,20
ENG106032-ENG102337-ECU ID2 PartNumber VW SW ID-Byte 20,8 ,20
ENG106032-ENG103171-ECU ID2 PartNumber VW SW ID-Byte 3,0 ,20
ENG106032-ENG99780-ECU ID2 PartNumber VW SW ID-Byte 4,9 ,20
ENG106032-ENG101635-ECU ID2 PartNumber VW SW ID-Byte 5,5 ,20
ENG106032-ENG100290-ECU ID2 PartNumber VW SW ID-Byte 6,9 ,20
ENG106032-ENG101242-ECU ID2 PartNumber VW SW ID-Byte 7,7 ,20
ENG106032-ENG101974-ECU ID2 PartNumber VW SW ID-Byte 8,0 ,20
ENG106032-ENG100834-ECU ID2 PartNumber VW SW ID-Byte 9,3 ,20
ENG106033-ENG103506-ECU ID3 HW ID VW-Byte 1,0 ,3
ENG106033-ENG100432-ECU ID3 HW ID VW-Byte 2,0 ,3
ENG106033-ENG103171-ECU ID3 HW ID VW-Byte 3,5 ,3
ENG106034-ECU ID4 VW Tester ID,00 00 00 00 14 BF B1 31 31 34 ,10
ENG108997-ENG103506-Software Version Number-Byte 1,± ,4
ENG108997-ENG100432-Software Version Number-Byte 2,1 ,4
ENG108997-ENG103171-Software Version Number-Byte 3,1 ,4
ENG108997-ENG99780-Software Version Number-Byte 4,4 ,4
ENG108998-ENG103506-Software Version Number(Front)-Byte 1,0 ,4
ENG108998-ENG100432-Software Version Number(Front)-Byte 2,3 ,4
ENG108998-ENG103171-Software Version Number(Front)-Byte 3,2 ,4
ENG108998-ENG99780-Software Version Number(Front)-Byte 4,9 ,4
ENG109228-System Data Part 1 (rear),00 04 01 59 A9 00 ,6
ENG109230-System Data Part 10 (rear),30 30 31 30 30 30 31 36 32 36 31 ,11
ENG109232-System Data Part 11 (rear),00 ,1
ENG109234-System Data Part 12 (rear),3F ,1
ENG109236-System Data Part 13 (rear),7E 40 00 ,3
ENG109238-System Data Part 2 (rear),00 00 00 00 10 84 00 00 ,8
ENG109240-System Data Part 3 (rear),00 01 00 01 02 00 05 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,24
ENG109242-System Data Part 4 (rear),00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,24
ENG109244-System Data Part 5 (rear),00 00 00 0B 00 03 3D 00 00 FF FF 7E 40 00 ,14
ENG109246-System Data Part 6 (rear),01 10 09 C2 ,4
ENG109248-System Data Part 7 (rear),06 10 17 62 61 97 36 24 01 05 FE 00 00 00 00 00 ,16
ENG109250-System Data Part 8 (rear),05 57 35 2E 98 40 64 25 79 03 03 02 00 00 00 00 ,16
ENG109252-System Data Part 9 (rear),30 30 30 30 30 30 30 30 37 35 30 34 30 32 42 52 46 30 30 31 31 37 31 30 30 36 31 31 ,28
ENG109253-System Data Part1,00 00 01 0C 16 02 00 00 00 01 00 11 00 0F D9 00 00 58 89 00 02 02 04 04 00 00 00 00 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8F 12 12 12 00 02 01 00 00 00 ,56
ENG109254-System Data Part2,00 00 00 00 00 00 65 92 74 7D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 30 30 30 30 30 30 37 35 30 34 30 32 00 00 07 07 07 07 07 07 07 07 07 07 07 07 07 00 00 06 00 00 06 02 02 06 06 05 05 07 07 07 02 05 06 01 06 07 04 07 07 03 03 05 06 07 05 07 07 00 07 04 02 01 01 03 05 04 07 07 07 07 03 07 07 00 02 01 00 00 00 00 01 01 00 00 00 00 01 02 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 03 00 00 00 00 00 01 00 00 01 00 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 ,216
ENG109255-System Data Part3,FF FF 08 5E 03 02 DD E5 00 46 26 D9 5E FF FF 08 CD 01 02 89 61 00 42 36 D1 39 FF FF 08 B1 01 02 42 CC 00 3E 55 12 B4 FF FF 08 C1 04 02 22 86 00 3C FA A4 B0 FF FF 08 C1 08 02 22 86 00 3C FA A5 0A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 02 0A 00 84 AC 22 E0 FE 00 00 00 00 00 00 00 00 A5 FF ,174
ENG109256-System Data Part4,10 09 17 04 14 91 84 32 01 01 00 00 00 00 42 52 46 2D 30 30 31 31 37 2E 30 39 2E 31 30 30 30 30 31 30 34 31 34 31 32 31 30 31 30 30 35 54 55 45 52 2D 53 47 20 46 54 20 20 20 30 30 30 31 35 33 30 35 35 30 ,68
ENG109257-System Data Part5,03 31 3D 42 98 83 30 00 05 06 00 00 00 00 00 00 00 00 00 00 ,20
ENG109258-System Data Part6,FF FE 00 FF FF FF FF FF FF FF FF FF FF FF FF FF 00 01 00 01 FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 ,38
ENG109259-System Data Part7,00 ,1
ENG109260-System Data Part8,3F ,1
ENG109263-System Parameter Part16,FF 11 00 01 81 C8 F6 30 39 16 06 17 00 00 ,14
ENG109264-System Parameter Part-17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F 2A 0A 08 03 79 2A 0A 3D 00 19 00 00 00 00 00 00 00 00 00 00 00 C2 42 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
ENG109265-System Parameters Part 1 (rear),74 9E 0F 34 00 05 6F 50 ,8
ENG109266-System Parameters Part 10 (rear),00 ,1
ENG109267-System Parameters Part 2 (rear),0C A8 0E 56 53 65 00 00 06 08 10 1E 50 96 3F 48 84 00 5A 3F 01 FF 58 44 ,24
ENG109268-System Parameters Part 3 (rear),3E 28 64 50 3E 3E 3E 3E 8A 92 B2 99 07 07 07 87 FB 84 65 34 00 44 28 46 ,24
ENG109269-System Parameters Part 4 (rear),07 B7 82 C1 73 46 10 27 3C 85 14 2B 0D 20 08 0C ,16
ENG109270-System Parameters Part 5 (rear),87 51 12 1B 37 83 A4 7D 0C 13 C5 18 B4 22 19 FF ,16
ENG109271-System Parameters Part 6 (rear),00 19 19 3E 42 71 77 BB BC FF 00 5A 6B CA D6 FF 00 2D 33 66 CC FF DF 77 6B 5E C6 1E 03 64 83 02 51 50 1F 7F 7D 00 ,38
ENG109272-System Parameters Part 7 (rear),0E 46 20 20 20 0D 03 02 02 0D 0D 5A 34 32 03 22 05 02 ,18
ENG109273-System Parameters Part 8 (rear),03 00 00 D0 ,4
ENG109274-System Parameters Part 9 (rear),B6 E5 A4 3F B7 E5 08 E0 0F 0A E0 0C 9E E6 06 A1 D0 26 0D A6 94 9E E7 07 A6 FF B7 B6 B7 B7 10 B8 81 9D 9D 9D 9D 81 D0 1C ,40
ENG109279-System_Parameter_0,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 ,16
ENG109280-System_Parameter_1,E4 00 4C 00 0C 7A 0F 87 69 9E 00 00 05 08 0C 10 ,16
ENG109281-System_Parameter_10,1E 28 37 46 5A 64 00 03 07 0A 0E 0F 28 1E 0A 75 ,16
ENG109282-System_Parameter_11,75 DF 72 5B DF 72 5B 07 03 00 28 14 00 64 02 00 ,16
ENG109283-System_Parameter_12,00 00 26 18 32 14 14 EA 00 00 00 00 00 00 00 00 ,16
ENG109284-System_Parameter_13,00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 0F ,16
ENG109285-System_Parameter_14,74 E0 1E E4 00 00 00 00 00 00 00 00 00 00 00 00 ,16
ENG109286-System_Parameter_15,00 00 ,2
ENG109287-System_Parameter_2,18 44 3F 62 9E 00 6E 3F 01 60 29 44 78 3C 64 55 ,16
ENG109288-System_Parameter_3,46 46 4B 46 8A 88 9E 96 91 8C 07 8A FD 72 B5 34 ,16
ENG109289-System_Parameter_4,00 53 50 19 07 B3 9B 61 73 2D 08 27 3C 86 14 28 ,16
ENG109290-System_Parameter_5,0A 1D 14 0A 87 51 12 20 37 A0 B6 7D A0 3F AA 47 ,16
ENG109291-System_Parameter_6,D9 22 19 0D 75 FF 32 75 C8 00 08 8C FF 2B 0E 80 ,16
ENG109292-System_Parameter_7,10 04 9C 00 02 0D F2 0D 32 0C 0F 32 0A 0A 03 32 ,16
ENG109293-System_Parameter_8,0A 03 20 20 20 0D 03 02 02 0D 0D 00 00 32 00 00 ,16
ENG109294-System_Parameter_9,00 00 00 00 00 00 14 00 00 03 2A 9B 00 00 00 00 ,16
ENG109297-System-Parameter Block,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 E4 00 4C 00 0C 7A 0F 87 69 9E 00 00 05 08 0C 10 18 44 3F 62 9E 00 6E 3F 01 60 29 44 78 3C 64 55 46 46 4B 46 8A 88 9E 96 91 8C 07 8A FD 72 B5 34 00 53 50 19 07 B3 9B 61 73 2D 08 27 3C 86 14 28 0A 1D 14 0A 87 51 12 20 37 A0 B6 7D A0 3F AA 47 D9 22 19 0D 75 FF 32 75 C8 00 08 8C FF 2B 0E 80 10 04 9C 00 02 0D F2 0D 32 0C 0F 32 0A 0A 03 32 0A 03 20 20 20 0D 03 02 02 0D 0D 00 00 32 00 00 00 00 00 00 00 00 14 00 00 03 2A 9B 00 00 00 00 1E 28 37 46 5A 64 00 03 07 0A 0E 0F 28 1E 0A 75 75 DF 72 5B DF 72 5B 07 03 00 28 14 00 64 02 00 00 00 26 18 32 14 14 EA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 0F 74 E0 1E E4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,242
ENG110034-VW-Identification,30 30 31 31 30 33 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 33 43 30 39 35 39 37 30 31 41 20 00 00 00 00 00 00 00 00 33 43 30 39 35 39 37 39 33 41 20 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 32 4A 33 38 36 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 33 32 39 45 56 5F 44 43 55 34 32 42 72 6F 73 65 44 72 69 76 65 53 69 64 65 00 00 00 00 41 30 33 30 30 34 01 81 C8 F6 30 39 16 06 17 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,242
ENG110126-MAS00478-Window_Lifter_Position-Reserved,00 ,8
ENG110126-ENG102781-Window_Lifter_Position-Data 1,0.25 ,8
ENG110126-ENG102143-Window_Lifter_Position-Data 2,8789.5 ,8
ENG110126-ENG103757-Window_Lifter_Position-Data 3,00 ,8
ENG110126-ENG101787-Window_Lifter_Position-Data 4,01 ,8
Elapsed Time: 00:39
Daar stond bij mij al 95, en werken het zelfde als bij jou nu.
Vraag:
Hi Dana
 Jan
Atw:
Hi Jan,
[Applications]
Address: 42
Output: CSV File
[start]
Regards,
Dana
Stond eigenlijk al in haar antwoord.
Ja maar zoals ik bovenstaande al zei kan je die niet wijzigen en moet je de andere hebben.
Had de verkeerde gepakt, niet goed gekeken. Heb het even gewijzigd
ENG109279-System_Parameter_0,7F BE 0F 34 00 0D C3.  51 95 F2 07 E4 E4 62 00 28 ,16
Mail naar Rosstech
Hi Dana
I have posted it on the forum, and tested your suggestion and it seems to work. A chance in ENG109279-System_Parameter_0,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 ,16 is working.
We tested it on the dutch passat forum.
http://forum.vwpassat.nl/
Best reguards Jan
