Diver Geplaatst 5 oktober, 2013 Rapporteer Share Geplaatst 5 oktober, 2013 Ik heb een aantal fouten waar ik wat meer info over zoek, om ze op te lossen Address 19: CAN Gateway Labels: 3C0-907-530.lbl Part No SW: 3C0 907 530 Q HW: 3C0 907 951 Component: J533 Gateway H13 0172 Revision: H13 Serial number: 3690P10C141166 Coding: F9807F4E400602002002 Shop #: WSC 12345 123 12345 VCID: 2F670D65BE066D1 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 19 Mileage: 110684 km Time Indication: 0 Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 H HW: 1T0 035 680 F Component: RNS-MID H06 4120 Revision: AB001001 Serial number: VWZ6Z7L7135074 Coding: 02010400010000100000 Shop #: WSC 00000 000 00000 ASAM Dataset: ------------------------- ------ VCID: 336F0115922E491 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V9 7918 1 Fault Found: 01042 - Control Module; Not Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 2 Reset counter: 235 Mileage: 110680 km Time Indication: 0 Date: 2013.10.05 Time: 10:31:08 Address 53: Parking Brake Labels: 3C0-907-801-53.clb Part No SW: 3C0 907 801 B HW: 3C0 907 801 B Component: EPB VC8HC001 013 0001 Revision: 013 Coding: 0000012 Shop #: WSC 00183 211 05007 VCID: 2143FB5DF8D2CB1 1 Fault Found: 02844 - Lamp for Automatic Parking Function 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 4 Fault Frequency: 2 Reset counter: 19 Mileage: 110664 km Time Indication: 0 Date: 2013.10.05 Time: 09:13:50 Freeze Frame: Voltage: 13.97 V Count: 64 Address 56: Radio (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 H HW: 1T0 035 680 F Component: RNS-MID H06 4120 Revision: AB001001 Serial number: VWZ6Z7L7135074 Coding: 02010400010000100000 Shop #: WSC 00000 000 00000 ASAM Dataset: ------------------------- ------ VCID: 336F0115922E491 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V9 7918 1 Fault Found: 01042 - Control Module; Not Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 2 Reset counter: 235 Mileage: 110680 km Time Indication: 0 Date: 2013.10.05 Time: 10:31:08 Address 77: Telephone Labels: 3C0-035-730.lbl Part No SW: 5N0 035 730 B HW: 5N0 035 730 B Component: J412 8502 Revision: 00015000 Serial number: 0000B7A090504 Coding: 0020055 Shop #: WSC 00066 000 00000 VCID: 2757E54596F6351 4 Faults Found: 00385 - Positive Output Audio Channel for Speech/Telephone 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 235 Mileage: 110684 km Time Indication: 0 Date: 2013.10.05 Time: 10:31:12 00386 - Negative Output Audio Channel for Speech/Telephone 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 235 Mileage: 110684 km Time Indication: 0 Date: 2013.10.05 Time: 10:31:12 02794 - Cell-Phone Prep. Control Head (E508) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 235 Mileage: 110684 km Time Indication: 0 Date: 2013.10.05 Time: 10:31:12 02749 - Control Module / Control Head for Telephone (J738) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 235 Mileage: 110684 km Time Indication: 0 Date: 2013.10.05 Time: 10:31:14 b.v.d Jan Link naar reactie Delen op andere sites More sharing options...
0 navi16 Geplaatst 5 oktober, 2013 Rapporteer Share Geplaatst 5 oktober, 2013 heb je hier gekeken Jan viewtopic.php?f=160&t=42765 Link naar reactie Delen op andere sites More sharing options...
0 Diver Geplaatst 5 oktober, 2013 Auteur Rapporteer Share Geplaatst 5 oktober, 2013 heb je hier gekeken Janviewtopic.php?f=160&t=42765 ik had het goed gedaan de code klopte. Dit is de oude code 3DFD9C44C62002, en in de log staat de nieuwe en die is F9807F4E400602002002. Gelukt bij Lucas? grt Jan Link naar reactie Delen op andere sites More sharing options...
0 navi16 Geplaatst 5 oktober, 2013 Rapporteer Share Geplaatst 5 oktober, 2013 Zeker weten !!! Link naar reactie Delen op andere sites More sharing options...
0 Robl Geplaatst 8 januari, 2014 Rapporteer Share Geplaatst 8 januari, 2014 Jan, ben je hier nog uitgekomen? heb nu ook een tsoenamie van fouten, bij mij na verwisselen van gateway (nu q-versie) dacht appeltje eitje ...................... maar nu de fouten oplossen Link naar reactie Delen op andere sites More sharing options...
0 Diver Geplaatst 8 januari, 2014 Auteur Rapporteer Share Geplaatst 8 januari, 2014 Heb de fouten een paar keer gewist met VCDS, en heb nog wat dingen gecontroleerd maar niet veel veranderd. heb nu wel een stuk minder fouten. Verder geen problemen met de auto. Ben benieuwd hoe het bij jou gaat. Als je wat dingen vind laat het even weten. grt Jan Link naar reactie Delen op andere sites More sharing options...
0 Robl Geplaatst 9 januari, 2014 Rapporteer Share Geplaatst 9 januari, 2014 Jan, Heb ook even alles langs gelopen. En gecontroleerd welke bit naar welke bit gaat (7-byte naar 10-byte) Voor de wisseling had ik geen fouten. Na de wisseling zie ik in VCDS een paar verdachte zaken nadat ik de coding van 7-byte naar 10-byte heb omgerekend: 03bit3 ik zou geen park assist(76) hebben-> klopt sowieso niet, ga ik aanpassen 03bit4 ik zou aux heating(7D) hebben, gaat volgens mij om de standkachel (let op er staat "aux heating" en een aparte bit voor "aux heater"! 03bit6 ik geen trailer (69) hebben-> klopt niet 05bit2 ik zou geen telefoonmodule hebben-> klopt sowieso niet, ga ik aanpassen 08bit4 ik zou na omrekening een 4 deurs sedan hebben, heb dit meteen veranderd in variant (is bit5)->deze bit ga ik toch even terugzetten Link naar reactie Delen op andere sites More sharing options...
0 Diver Geplaatst 14 januari, 2014 Auteur Rapporteer Share Geplaatst 14 januari, 2014 Beetje laat maar ik heb het zo gedaan, eerst een printscreen van alle bytes, toe alles gecontroleerd met de nieuwe gateway. en toe nogmaals gecontroleerd met de converter. B6 CAN convertor 7 byte to 10 byte.xls Gatway C.doc Link naar reactie Delen op andere sites More sharing options...
0 Robl Geplaatst 14 januari, 2014 Rapporteer Share Geplaatst 14 januari, 2014 Dat had ik beter ook kunnen doen. Blijkbaar werkt de nieuwe gateway iets anders. Bij de oude gateway was blijkbaar de trekhaak niet gecodeerd maar werd wel herkend. Bij de nieuwe gateway krijg je een fout als de trekhaak niet is aangevinkt. Link naar reactie Delen op andere sites More sharing options...
Diver
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 19
Mileage: 110684 km
Time Indication: 0
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 235
Mileage: 110680 km
Time Indication: 0
Date: 2013.10.05
Time: 10:31:08
Revision: 013
Coding: 0000012
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 19
Mileage: 110664 km
Time Indication: 0
Date: 2013.10.05
Time: 09:13:50
Freeze Frame:
Voltage: 13.97 V
Count: 64
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 235
Mileage: 110680 km
Time Indication: 0
Date: 2013.10.05
Time: 10:31:08
Coding: 0020055
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 235
Mileage: 110684 km
Time Indication: 0
Date: 2013.10.05
Time: 10:31:12
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 235
Mileage: 110684 km
Time Indication: 0
Date: 2013.10.05
Time: 10:31:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 235
Mileage: 110684 km
Time Indication: 0
Date: 2013.10.05
Time: 10:31:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 235
Mileage: 110684 km
Time Indication: 0
Date: 2013.10.05
Time: 10:31:14
b.v.d Jan
8 antwoorden op deze vraag
