Marco456 Geplaatst 5 juni, 2009 Rapporteer Share Geplaatst 5 juni, 2009 Ik zag dat er een nieuwe firmware is voor de RNS 510, versie 1100 Hij is te verkrijgen bij be dealer, en hij staat ook te downloaden bij nieuwsgroepen: http://www.binsearch.net/?q=RNS510+firmware&max=25&adv_age=&server= Ik heb er geen dus kan het NIET testen en natuurlijk gebruik op eigen risico!!!! Link naar reactie Delen op andere sites More sharing options...
0 Marco456 Geplaatst 9 juni, 2009 Auteur Rapporteer Share Geplaatst 9 juni, 2009 Extra info: Volkswagen RNS 510 Firmware Upgrade to version 1100 / 1102 Version 1100 Firmware for the Volkswagen RNS 510 has been released, the update upgrades the version to the B version and gives new features such as • Bluetooth audio support • AV output • Faster touchscreen response • New volume location at bottom of screen without any dimming • Bluetooth Audio Support • New Balance Fader Units that can be upgraded include • 1T0 035 680 (1T0035680) from software version 0421, 0520, 1000, 800 and 900 to version 1100. • 1T0 035 680 A (1T0035680A) from software version 0421, 0520, 1000, 800 and 900 to version 1100. • 1T0 035 680 B (1T0035680B) from software version 0421, 0520, 1000, 800 and 900 to version 1100. • 7L6 035 680 (7L6035680) from software version 0522, 1002 and 1022 to version 1102. • 7L6 035 680 A (7L6035680A) from software version 0522, 1002 and 1022 to version 1102. • 7L6 035 680 B (7L6035680B) from software version 0522, 1002 and 1022 to version 1102. • 1Z0 035 680A (1Z0035680A) After the process is complete you will have a B revision unit. The firmware can be downloaded from here in a NRG format and should be burnt to DVD +RW (CDR is also ok) using Nero. Alternatively you can download the ISO version from here. Warning! When this upgrade is performed it will delete all the music and require your maps to be reloaded (last addresses and home address are retained however as are other settings). There is also a remote chance of your ‘bricking’ your unit. The process will take around 60 minutes. Link naar reactie Delen op andere sites More sharing options...
0 Dominion Geplaatst 10 juni, 2009 Rapporteer Share Geplaatst 10 juni, 2009 Hoe weet je welke firmware je momenteel draait? Link naar reactie Delen op andere sites More sharing options...
Marco456
2 antwoorden op deze vraag
