Monday,19,August,2013,18:32:44:10074 VCDS Version: Beta 11.2.0 Data version: 20110305
Chassis Type: 3C0 Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 53 55 56 62 72 76 VIN: WVWZZZ3Cxxxxxxxx Mileage: 122230km/75950miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: Malfunction 0010 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Revision: 00H54000 Serial number: 01000008151495 Coding: E78A8F0510041A1E47000F0014000000000B5D435C100100000000000000 Shop #: WSC 12345 159 67893 VCID: 71EDD1F71369 Subsystem 1 - Part No: 3C1 955 419 A Component: Wischer 040208 003 0205 Coding: 00046997 Shop #: WSC 12345 Subsystem 2 - Part No: 1K0 955 559 AF Component: RLS 200308 046 0204 Coding: 00471077 Shop #: WSC 12345 3 Faults Found: 01800 - Light Switch (E1) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 110 Mileage: 122184 km Time Indication: 0 Date: 2013.08.18 Time: 17:04:00 Freeze Frame: OFF Voltage: 12.30 V OFF ON OFF OFF OFF 02071 - Local Databus 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 100 Mileage: 121498 km Time Indication: 0 Date: 2013.08.14 Time: 08:15:00 Freeze Frame: OFF Voltage: 12.30 V OFF ON OFF OFF OFF 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 100 Mileage: 121498 km Time Indication: 0 Date: 2013.08.14 Time: 08:15:00 Freeze Frame: OFF Voltage: 12.35 V OFF ON OFF OFF OFF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl Part No SW: 5N0 035 342 E HW: 5N0 035 342 E Component: SG EXT.PLAYER H13 0240 Revision: A1001003 Serial number: 7660126082 Coding: 010000 Shop #: WSC 01357 011 00200 VCID: 295DF997FB39 1 Fault Found: 03138 - Input AUX IN 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 5 Mileage: 119370 km Time Indication: 0 Date: 2013.07.22 Time: 23:28:51
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 B HW: 1T0 035 680 A Component: RNS-MID H04 1200 Revision: AB001001 Serial number: VWZ6Z7H9076042 Coding: 000004000400001200 Shop #: WSC 05314 000 00000 ASAM Dataset: ------------------------- ------ VCID: 2D550D87CFD1 1 Fault Found: 00879 - Connection to Speaker Front Right 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 110 Mileage: 122184 km Time Indication: 0 Date: 2013.08.18 Time: 16:19:27
Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 R HW: 3C0 959 433 R Component: KSG PQ46 ELV 042 0472 Revision: 00042000 Serial number: VWZCZ000000000 Coding: 1991020051030E7630029C1D70084FCE107801 Shop #: WSC 05311 000 00000 VCID: 397D29D70B99 Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 Part No: 3C0 951 171 C Component: Neigungssensor 004 0611 Part No: 3C0 951 171 C Component: Innenraumueberw.004 0611 3 Faults Found: 01135 - Interior Monitoring Sensors 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 110 Time Indication: 0 00323 - Vehicle Inclination Sensor (G384) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 110 Mileage: 122184 km Time Indication: 0 Date: 2013.08.18 Time: 16:50:06 01134 - Alarm Horn (H12) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 110 Mileage: 122184 km Time Indication: 0 Date: 2013.08.18 Time: 16:50:06
Address 56: Radio (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 B HW: 1T0 035 680 A Component: RNS-MID H04 1200 Revision: AB001001 Serial number: VWZ6Z7H9076042 Coding: 000004000400001200 Shop #: WSC 05314 000 00000 ASAM Dataset: ------------------------- ------ VCID: 2D550D87CFD1 1 Fault Found: 00879 - Connection to Speaker Front Right 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 110 Mileage: 122184 km Time Indication: 0 Date: 2013.08.18 Time: 16:19:27
37 en 56 zijn bijden opgelost, de speaker werkt gewoon :/ geen idee wat hier mis was maar het werkt !
Bij 2E dit foutje gaat er maar niet uit lig er niet echt wakker van
Bij 09 de licht schakelaar heb ik even gewisseld geen groot probleem hier weet ik van
maar die locale databus heeft blijkbaar te meken met de configuratie van Rain Closing, kan dreke/ of iemand zeggen hoe ik die rainclosing uitzet desnoods tis niet dat mijn ruiten veel openstaan ..
ik heb GEEN idee wat er bij 46 gebeurd is heb de codes gewist en staan er niet op nu maar enige input van wat dit kan veroorzaakt zijn mag altijd
grts, John
