ik weet het echt niet, raar is dit..
hierbij het Komplete log van gister avond..
iemand die er misschien wat kan uithalen..
01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 26-Auto Roof -- Status: Cannot be reached 1100 36-Seat Mem. Drvr -- Status: Malfunction 0010 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 63-Entry Assist,D -- Status: Cannot be reached 1100 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-021-BMM.clb Part No SW: 03G 906 021 MR HW: 028 101 211 9 Component: R4 2,0L EDC G000SG 9389 Revision: --H01--- Serial number: VWZCZ000000000 Coding: 0000072 Shop #: WSC 66565 257 00032 VCID: 7BF511673A10BBC6C11-802E No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: None VCID: 55A167DFBCF48DB6975-8000 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None Part No SW: 3AD 907 044 G HW: 3AD 907 044 G Component: Climatronic H03 0404 Revision: 00002001 Coding: 0010004803 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_ACClimaBHBVW411 A01001 ROD: EV_ACClimaBHBVW411.rod VCID: 377DCD578EB85FA6659-8062 3 Faults Found: 13701376 - Function Restricted due to Missing Message(s) U1111 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Date: 2053.14.00 Time: 05:23:42 13701424 - Function Restricted due to Missing Message(s) U1111 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Date: 2053.14.00 Time: 05:23:42 9479189 - Signal Line for Air Quality Sensor B10A4 15 [009] - Open or Short to Plus Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Date: 2053.14.00 Time: 05:23:42 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl Part No SW: 3C0 937 049 B HW: 3C0 937 049 B Component: Bordnetz-SG H31 0904 Revision: 00H31000 Serial number: 00000001394933 Coding: E4888F0700041A0F000000000F000000000959435C Shop #: WSC 05311 123 12345 VCID: 285F1E2B9B06C05EFC3-807D Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB Component: Wischer VW461 012 0503 Coding: 00065493 Shop #: WSC 05311 Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB Component: RegenLichtSens 005 0605 Coding: 00217125 Shop #: WSC 05311 1 Fault Found: 00830 - Convertible Top Control Module (J256) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Time Indication: 0 Freeze Frame: ON Voltage: 11.40 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 3C0-909-605.lbl Part No SW: 3C0 909 605 A HW: 3C0 909 605 A Component: 0B AIRBAG VW8 028 2321 Revision: 06028000 Serial number: 0034ZS2H8VFE Coding: 0012354 Shop #: WSC 05311 000 08193 VCID: 24470A1BE72E243ED0B-8071 Subsystem 1 - Serial number: 6332MSME23774770 Subsystem 2 - Serial number: 6342MSME0353C780 Subsystem 3 - Serial number: 6351HTS62M7UH6G2 Subsystem 4 - Serial number: 6361HTS62M7U9IG2 Subsystem 5 - Serial number: 6371VTS62UE5LON2 Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ Component: J0527 0030 Revision: 00032000 Serial number: 3C5953507CN Coding: 0001711 Shop #: WSC 05314 000 00000 VCID: 74E73A5B174EF4BE80B-8021 Subsystem 1 - Part No: 3C8 959 537 D Component: E221__MFL-TK6 H06 0022 Coding: 00000226 Shop #: WSC 00000 1 Fault Found: 00002 - Transmission Control Unit 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb Part No SW: 3C8 920 870 A HW: 3C8 920 870 A Component: KOMBI H19 0023 Serial number: 00000000000000 Coding: 161D00 Shop #: WSC 05311 115 12345 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020 ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod VCID: 29591B2F480CF956E3D-807C 1 Fault Found: 12715520 - Function Restricted due to Missing Message(s) U1111 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Date: 2053.14.00 Time: 05:23:41 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: 1K0-815-071.clb Part No: 1K0 815 071 AD Component: Zuheizer 022 3907 Revision: 00022000 Serial number: 09020188000000 Coding: 0000011 Shop #: WSC 00093 211 87446 VCID: 67DD5D1756980F26359-8032 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb Part No SW: 3C0 907 530 E HW: 3C0 907 951 Component: J533__Gateway H10 0080 Revision: H10 Serial number: 1200P084200045 Coding: F980FF2E440E021002 Shop #: WSC 05311 123 12345 VCID: 23450907E2202306A91-8076 2 Faults Found: 00830 - Convertible Top Control Module (J256) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Time Indication: 0 Date: 2053.14.00 Time: 05:23:43 02010 - Left Entry Assistance Control Module (J572) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Time Indication: 0 Date: 2053.14.00 Time: 05:23:43 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 HW: 3C0 959 433 Component: IMMO 038 0347 Revision: 00038000 Serial number: VWZCZ000000000 Shop #: WSC 00093 211 87446 VCID: E7DDDD17D6988F26B59-80B2 Subsystem 1 - Part No: 3C0 905 861 J Component: ELV 029 0380 3C0905861J ELV 029 0380 No fault code found. ------------------------------------------------------------------------------- Address 26: Auto Roof Cannot be reached ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl Part No SW: 3C0 959 760 A HW: 3C0 959 760 A Component: Sitzverstellung 0601 Revision: 00002000 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 2B55E1278AF0EB46111-807E 2 Faults Found: 02346 - Switch for Memory Position 2 (E219) 003 - Mechanical Failure 02347 - Switch for Memory Position 3 (E220) 003 - Mechanical Failure ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 H HW: 1T0 035 680 H Component: RNS-MID H71 4120 Revision: AB001001 Serial number: VWZ6Z7M4269087 Coding: 04000402040000910010 Shop #: WSC 05311 123 08193 VCID: 3365F94792C0B386591-8066 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V12 8195 4 Faults Found: 00872 - Bass Speaker Rear Left (R15) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 222 Mileage: 204792 km Time Indication: 0 00821 - Antenna 2 for Radio (R93) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 222 Mileage: 204792 km Time Indication: 0 01523 - Microphone for Telephone (R38) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Time Indication: 0 Date: 2053.14.00 Time: 05:23:50 03138 - Input AUX IN 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Time Indication: 0 Date: 2053.14.00 Time: 05:29:18 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: None VCID: 55A167DFBCF48DB6975-8000 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 144 H Component: EPS_ZFLS Kl.1 1502 Shop #: WSC 00000 000 00000 VCID: 306FF64BA3D6889E243-8065 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 HW: 3C0 959 433 Component: KSG PQ46 ELV 038 0434 Revision: 00038000 Serial number: VWZCZ000000000 Coding: 18900A080186C27F7F061F1FF008CFCE703D00 Shop #: WSC 00250 211 91695 VCID: E7DDDD17D6988F26B59-80B2 Subsystem 1 - Component: Sounder No Answer Subsystem 2 - Part No: 3C5 951 171 Component: Neigungssensor 001 0507 Subsystem 3 - Part No: 3C5 951 171 Component: Innenraumueberw.001 0507 2 Faults Found: 00830 - Convertible Top Control Module (J256) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Time Indication: 0 Date: 2053.14.00 Time: 05:23:44 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Time Indication: 0 Date: 2053.14.00 Time: 05:28:50 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl Part No: 1K0 959 702 L Component: Tuer-SG 024 2439 Coding: 0000502 Shop #: WSC 05311 000 08193 VCID: 387FCE6B4BA650DE6C3-806D No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3C0-907-801-53.clb Part No SW: 3C0 907 801 B HW: 3C0 907 801 B Component: EPB VC8HC001 012 0001 Revision: 012 Coding: 0000011 Shop #: WSC 05311 000 00000 VCID: 2149030FF83C3116BBD-8074 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 H HW: 1T0 035 680 H Component: RNS-MID H71 4120 Revision: AB001001 Serial number: VWZ6Z7M4269087 Coding: 04000402040000910010 Shop #: WSC 05311 123 08193 VCID: 3365F94792C0B386591-8066 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V12 8195 4 Faults Found: 00872 - Bass Speaker Rear Left (R15) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 222 Mileage: 204792 km Time Indication: 0 00821 - Antenna 2 for Radio (R93) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 222 Mileage: 204792 km Time Indication: 0 01523 - Microphone for Telephone (R38) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Time Indication: 0 Date: 2053.14.00 Time: 05:23:50 03138 - Input AUX IN 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 222 Mileage: 204794 km Time Indication: 0 Date: 2053.14.00 Time: 05:29:18 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl Part No: 1K0 959 703 F Component: Tuer-SG 021 2417 Coding: 0000144 Shop #: WSC 05311 000 08193 VCID: 3365F94752C0B386591-8066 No fault code found. ------------------------------------------------------------------------------- Address 63: Entry Assist,D Cannot be reached ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl Part No: 1K0 959 704 F Component: Tuer-SG 021 2417 Coding: 0000144 Shop #: WSC 05311 000 08193 VCID: 3467FA5B57CEB4BE40B-8061 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 3C0-919-283.lbl Part No SW: 3C0 919 283 B HW: 3C0 919 283 B Component: Parkhilfe 8-Kan 004 0011 Revision: 00004000 Serial number: 82930501002776 Coding: 0000014 Shop #: WSC 05311 000 00000 VCID: 285F1E2B9B06C05EFC3-807D No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 3C0-035-729.lbl Part No SW: 3C0 035 729 B HW: 3C0 035 729 B Component: Telefon 4709 Revision: 00006000 Serial number: 0000000612206 Coding: 0016103 Shop #: WSC 05311 000 00000 VCID: 224B0C03FD3A2A0EA27-8077 No fault code found.
