R32 Geplaatst 9 december, 2018 Rapporteer Share Geplaatst 9 december, 2018 Toevallig gezien op 15-11-2011. Heeft bijgaande codering misschien iets te maken met foutmeldingen in adres: 09, 19, 42, 52, 62, 72 ?? Er is nl geen sunroof aanwezig. Alle deursloten en ramen werken namelijk altijd normaal Monday,23,March,2015,15:51:46:10074 VCDS Version: Beta 11.2.0 Data version: 20110305 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3C0 Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 52 53 56 5D 62 65 69 72 76 77 VIN: WVWZZZ3CZ7E200311 Mileage: 133120km/82716miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 5D-Operations -- Status: OK 0000 62-Door, Rear Left -- Status: Malfunction 1010 65-Tire Pressure -- Status: Malfunction 0010 69-Trailer -- Status: OK 0000 72-Door, Rear Right -- Status: Malfunction 1010 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03H-906-032-BLV.lbl Part No SW: 03H 906 032 AB HW: 03H 906 032 AB Component: P3.2-FSI-EU4 G00 0764 Revision: 5GH04--- Serial number: VWZCZ000000000 Coding: 0000175 Shop #: WSC 05311 000 12345 VCID: 62CFAEBBC68F No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-300-0xx.lbl Part No SW: 02E 300 011 BN HW: 02E 927 770 AE Component: GSG DSG 081 1302 Revision: 04508010 Serial number: 00000702150503 Coding: 0000020 Shop #: WSC 44551 111 44551 VCID: 5CB39043E4EB No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl Part No SW: 3C0 614 109 A HW: 3C0 614 109 A Component: ESP 440 C4 H018 0001 Revision: H018 Serial number: 0775176502 Coding: 0030151 Shop #: WSC 05311 000 00000 VCID: 1C33D043A46B No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3C0-907-044.lbl Part No SW: 3C0 907 044 BB HW: 3C0 907 044 BB Component: ClimatronicPQ46 112 0606 Revision: 00112021 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 62CFAEBBC68F No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE Component: Bordnetz-SG H52 2002 Revision: 00H52000 Serial number: 00000006792065 Coding: E58C8F0700041A00470A00000F00000000095D435C0001 Shop #: WSC 05311 000 00000 VCID: 6CD3C083344B Subsystem 1 - Part No: 3C1 955 419 A Component: Wischer 020207 003 0205 Coding: 00046997 Shop #: WSC 05311 Subsystem 2 - Part No: 1K0 955 559 AB Component: RLS 080307 020 0105 Coding: 00208933 Shop #: WSC 05311 1 Fault Found: 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 241 Mileage: 131376 km Time Indication: 0 Date: 2015.01.28 Time: 13:05:00 Freeze Frame: OFF Voltage: 12.10 V OFF ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 3C0-909-605.lbl Part No SW: 3C0 909 605 N HW: 3C0 909 605 N Component: 1B AIRBAG VW8R 032 2522 Revision: 13032000 Serial number: 003B2P3VJNVJ Coding: 0012610 Shop #: WSC 05311 000 00000 VCID: 316D11F7D3E9 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl Part No SW: 3C0 953 549 K HW: 3C0 953 549 K Component: J0527 0015 Revision: 00006000 Serial number: 3C9953507AE Coding: 0001312 Shop #: WSC 05311 000 00000 VCID: 346318E32CFB Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3C0-920-xxx-17.lbl Part No SW: 3C0 920 870 T HW: 3C0 920 870 T Component: KOMBIINSTRUMENT VD1 1614 Revision: V0007000 Serial number: 00000000000000 Coding: 0007105 Shop #: WSC 00011 888 96745 VCID: 346318E32CFB No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530.lbl Part No SW: 3C0 907 530 C HW: 3C0 907 951 A Component: Gateway 007 0040 Revision: 00007000 Serial number: 0700C073150141 Coding: BFFD9E44E62002 Shop #: WSC 00264 211 85522 VCID: 214DE1B78309 2 Faults Found: 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 244 Mileage: 132862 km Time Indication: 0 Date: 2015.03.16 Time: 12:01:32 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 7 Reset counter: 252 Mileage: 131126 km Time Indication: 0 Date: 2015.01.18 Time: 21:33:32 ------------------------------------------------------------------------------- Address 22: AWD Labels: 1K0-907-554.lbl Part No: 1K0 907 554 K Component: Haldex 4Motion 1118 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 356525E72781 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 T HW: 3C0 959 433 T Component: IMMO 051 0383 Revision: 00051000 Serial number: VWZCZ000000000 Shop #: WSC 00264 211 80908 VCID: 3B7133DF01A5 Part No: 3C0 905 861 G Component: ELV 027 0380 3C0905861G ELV 027 0380 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: None Part No SW: 1K0 035 191 E HW: 1K0 035 191 E Component: J401 0206 Revision: 00016000 Serial number: VWZ1Z2F6365661 Coding: 0043402 Shop #: WSC 02747 127 92068 VCID: 2443E8A39C1B 1 Fault Found: 02766 - CD-access time 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 3 Fault Frequency: 3 Reset counter: 238 Mileage: 129885 km Time Indication: 0 Date: 2014.12.04 Time: 10:39:26 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 1K0 959 701 P HW: 1K0 959 793 L Component: J386 TUER-SG FT 1131 Revision: 32008001 Serial number: 00000531178302 Coding: 0000245 Shop #: WSC 05311 000 00000 VCID: 3B7133DF01A5 1 Fault Found: 01034 - Electric Window Thermal Protection Active; Driver 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 254 Reset counter: 247 Mileage: 129887 km Time Indication: 0 Date: 2014.12.04 Time: 11:14:57 ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x.lbl Part No: 1K1 909 144 L Component: EPS_ZFLS Kl.136 H07 1806 Shop #: WSC 02069 000 90108 VCID: 346318E32CFB No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 T HW: 3C0 959 433 T Component: KSG PQ46 RDK 051 0218 Revision: 00051000 Serial number: VWZCZ000000000 Coding: 0091020051030E763004941570084FCE705800 Shop #: WSC 00264 211 80908 VCID: 3B7133DF01A5 Part No: 1K0 951 605 D Component: LIN BACKUP HORN H07 9001 Part No: 3C0 951 171 C Component: Neigungssensor 004 0611 Part No: 3C0 951 171 C Component: Innenraumueberw.004 0611 1 Fault Found: 01517 - Control Module for Trailer/Towing Sensor (J345) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 16 Reset counter: 91 Mileage: 128983 km Time Indication: 0 Date: 2014.11.14 Time: 11:44:39 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl Part No SW: 1K0 959 702 P HW: 1K0 959 792 L Component: J387 TUER-SG BT 1131 Revision: 32008001 Serial number: 00000528678302 Coding: 0000244 Shop #: WSC 05311 000 00000 VCID: 3C7330C304AB 1 Fault Found: 01035 - Electric Window Thermal Protection Active; Passenger 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 254 Reset counter: 247 Mileage: 129887 km Time Indication: 0 Date: 2014.12.04 Time: 11:14:57 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3C0-907-801-53.lbl Part No SW: 3C0 907 801 E HW: 3C0 907 801 E Component: EPB VC8HC003 013 0003 Revision: 013 Coding: 0000012 Shop #: WSC 05311 000 00000 VCID: 2443E8A39C1B No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: None Part No SW: 1K0 035 191 E HW: 1K0 035 191 E Component: R 0206 Revision: 00016000 Serial number: VWZ1Z2F6365661 Coding: 0043402 Shop #: WSC 02747 127 92068 VCID: 2443E8A39C1B 1 Fault Found: 02766 - CD-access time 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 3 Fault Frequency: 3 Reset counter: 238 Mileage: 129885 km Time Indication: 0 Date: 2014.12.04 Time: 10:39:26 ------------------------------------------------------------------------------- Address 5D: Operations Labels: 3C0-035-151.lbl Part No SW: 3C0 035 151 C HW: 3C0 035 151 C Component: J738 011 0018 Revision: 00011000 Shop #: WSC 00000 000 00000 VCID: 183BCC535053 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl Part No SW: 1K0 959 703 P HW: 1K0 959 795 G Component: J388 TUER-SG HL 1119 Revision: 11006001 Serial number: 00000001415593 Coding: 0000208 Shop #: WSC 05311 000 00000 VCID: 3D753DC71FB1 1 Fault Found: 01036 - Electric Window Thermal Protection Active; Rear Left 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 47 Reset counter: 234 Mileage: 132540 km Time Indication: 0 Date: 2015.03.03 Time: 13:46:50 ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl Part No SW: 3C0 959 433 T HW: 3C0 959 433 T Component: RDK 0420 Revision: 00051000 Serial number: VWZCZ000000000 Coding: 0161211 Shop #: WSC 05311 000 00000 VCID: 3B7133DF01A5 1 Fault Found: 01477 - System Switched Off 000 - - Freeze Frame: Fault Status: 01110000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 102 Mileage: 129415 km Time Indication: 0 Date: 2014.11.23 Time: 18:15:28 ------------------------------------------------------------------------------- Address 69: Trailer Cannot be reached ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl Part No SW: 1K0 959 704 P HW: 1K0 959 794 G Component: J389 TUER-SG HR 1119 Revision: 11006001 Serial number: 00000001432135 Coding: 0000208 Shop #: WSC 05311 000 00000 VCID: 3E773ACB12B7 1 Fault Found: 01037 - Electric Window Thermal Protection Active; Rear Right 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 49 Reset counter: 234 Mileage: 132540 km Time Indication: 0 Date: 2015.03.03 Time: 13:46:50 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 3C0-919-283.lbl Part No SW: 3C0 919 283 C HW: 3C0 919 283 C Component: Parkhilfe 8-Kan 004 0013 Revision: 00004000 Serial number: 90630706506273 Coding: 0011024 Shop #: WSC 05311 000 00000 VCID: 295DF997FB39 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 3C0-035-730.lbl Part No SW: 7L6 035 730 HW: 7L6 035 730 Component: Telefon 2209 Revision: 00011000 Serial number: 0000000015370 Coding: 0020055 Shop #: WSC 05311 000 00000 VCID: EBD1439FB145 1 Fault Found: 00992 - Consumption Cut-Off Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 3 Reset counter: 243 Mileage: 132847 km Time Indication: 0 Date: 2015.03.09 Time: 16:31:24 End --------------------------------------------------------------------- coding Address 25 Immobilizer byte 8 sunroof.bmp Link naar reactie Delen op andere sites More sharing options...
0 R32 Geplaatst 9 december, 2018 Auteur Rapporteer Share Geplaatst 9 december, 2018 (aangepast) Sorry, Moet coderings afbeelding nog posten coding Address 25 Immobilizer byte 8 sunroof.bmp 9 december, 2018 aangepast door R32 Link naar reactie Delen op andere sites More sharing options...
0 dreke Geplaatst 12 december, 2018 Rapporteer Share Geplaatst 12 december, 2018 (aangepast) Gezien alle fouten "intermmittent" zijn, en dateren van 2014-2015 zou ik de fouten gewoon wissen en kijken of er wel een fout terugkomt. Die setting van sunroof doet er niet toe. Wat wel kan : in de gateway adres 69 (trekhaak) uitvinken, ofwel zit er geen trekhaak op of er is geen OEM module aanwezig. in de radio : code 0043402 wijzigen naar 0043400 (indien je geen CD wisselaar hebt, anders genereert die mogelijk een fout) de bandencontrole activeren (drukknop ingedrukt houden tot je een 'ping' hoort?? - afhankelijk van het systeem dat gemonteerd zit) grtz, dre 12 december, 2018 aangepast door dreke 2 Link naar reactie Delen op andere sites More sharing options...
R32
Chassis Type: 3C0
65 69 72 76 77
Coding: 0000175
VCID: 62CFAEBBC68F
Coding: 0000020
VCID: 5CB39043E4EB
Coding: 0030151
VCID: 1C33D043A46B
VCID: 62CFAEBBC68F
VCID: 6CD3C083344B
Coding: 00046997
Shop #: WSC 05311
Coding: 00208933
Shop #: WSC 05311
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 241
Mileage: 131376 km
Time Indication: 0
Date: 2015.01.28
Time: 13:05:00
Freeze Frame:
OFF
Voltage: 12.10 V
OFF
ON
OFF
OFF
OFF
Coding: 0012610
VCID: 316D11F7D3E9
Coding: 0001312
VCID: 346318E32CFB
Coding: 0007105
VCID: 346318E32CFB
VCID: 214DE1B78309
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 244
Mileage: 132862 km
Time Indication: 0
Date: 2015.03.16
Time: 12:01:32
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 252
Mileage: 131126 km
Time Indication: 0
Date: 2015.01.18
Time: 21:33:32
Coding: 0000001
VCID: 356525E72781
VCID: 3B7133DF01A5
Coding: 0043402
VCID: 2443E8A39C1B
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 238
Mileage: 129885 km
Time Indication: 0
Date: 2014.12.04
Time: 10:39:26
Coding: 0000245
VCID: 3B7133DF01A5
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Reset counter: 247
Mileage: 129887 km
Time Indication: 0
Date: 2014.12.04
Time: 11:14:57
VCID: 346318E32CFB
VCID: 3B7133DF01A5
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 16
Reset counter: 91
Mileage: 128983 km
Time Indication: 0
Date: 2014.11.14
Time: 11:44:39
Coding: 0000244
VCID: 3C7330C304AB
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Reset counter: 247
Mileage: 129887 km
Time Indication: 0
Date: 2014.12.04
Time: 11:14:57
Revision: 013
Coding: 0000012
VCID: 2443E8A39C1B
Component: R 0206
Coding: 0043402
VCID: 2443E8A39C1B
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 238
Mileage: 129885 km
Time Indication: 0
Date: 2014.12.04
Time: 10:39:26
Revision: 00011000
VCID: 183BCC535053
Coding: 0000208
VCID: 3D753DC71FB1
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 47
Reset counter: 234
Mileage: 132540 km
Time Indication: 0
Date: 2015.03.03
Time: 13:46:50
Component: RDK 0420
Coding: 0161211
VCID: 3B7133DF01A5
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 102
Mileage: 129415 km
Time Indication: 0
Date: 2014.11.23
Time: 18:15:28
Address 69: Trailer
Cannot be reached
Coding: 0000208
VCID: 3E773ACB12B7
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 49
Reset counter: 234
Mileage: 132540 km
Time Indication: 0
Date: 2015.03.03
Time: 13:46:50
Coding: 0011024
VCID: 295DF997FB39
Coding: 0020055
VCID: EBD1439FB145
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 243
Mileage: 132847 km
Time Indication: 0
Date: 2015.03.09
Time: 16:31:24
2 antwoorden op deze vraag
