Roy_01 Geplaatst 14 juni, 2018 Rapporteer Share Geplaatst 14 juni, 2018 (aangepast) Onderstaande kwam ik tegen op het Tiguan forum. Misschien leuk voor de gevorderde VCP-ers op het forum. Heb zelf geen VCP dus ook niet getest dus op eigen risico. Let op: <0,5 seconden kan leiden tot onbedoeld openen ramen/dak tijdens ontgrendelen deuren. ---------------------------------------------------------------------------------------------------------------------------------------------- Ok this is a nice future that do this.... In default it is 2 seconds that you must hold the fob key to close the windows and the folding mirrors ( if you have) So that was something i would like to have. No holding 2 seconds but 0,5 seconds This is how you do it...... You must have VCP or ODIS Go to channel 9 and then HEX here you write the 460 and tick the HEX like this... after that you must login to have access 42013 after that you will see this... in my car it says 3 time 14, 14 means 1.4 seconds in other cars it can say FF that's is about 2 seconds to change this click on that address and it will pop up this picture.... change the three numbers 14 to 05 and click OK now you can see that i have 05 click Write cells....it will take some seconds to write it here you can see the video... 14 juni, 2018 aangepast door Roy_01 2 Link naar reactie Delen op andere sites More sharing options...
Roy_01
like this...
and click OK
0 antwoorden op deze vraag
