klap functie spiegel met AB in combinatie met laatste versie VCDS
Diver
Aangezien er meerdere waren die de functie niet konden vinden in de nieuwere versie van VCDS heb ik Rosstech een mail gestuurd. en jullie belooft het te posten. Hier de mail wisseling.
1:
Hello can you help me out with this problem, previous it was possible with older versions of VCDS to  program the folding mirror so they work by pushing the lock button on the remote ( car key ) but now I can`t find it anymore, are there chances in the program, ore is it renamed.
1.Select [42-Door Elec, Driver]
2.Klik [security Access - 16]
3.enter security code "04354" and click op "Do it!"
4.Back in the previous menu , click  [Adaptation -10]
5.Selectthe next channel: (9)-System_Parameter_0-System Parameter Byte8 ( it should be a bit at the bottom )
6.now you See the value is 90. You have 2 options : 1.95 – on remote keep  lock button pressed to fold mirrors and unfold with motor on.
2.99 -  Keep  lock button pressed to fold mirror, and unfold by opening the door.
7.Klik op "Do it!" than  "Yes"
8.than you get the massage code accepted click ok
9.Now you are done...
Monday,19,March,2018,18:48:01:35994
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
   Part No SW: 3C0 959 701 A    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0329
   Revision: 12101005    Serial number: 0001530550
   Coding: 0011FF
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_DCU42BroseDriveSide A03004
   ROD: EV_DCU42BroseDriveSide_VW32.rod
   VCID: 26427CA5596B977442-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388__TSG-HL  005 1114
   Serial number: 00000000750402
   Coding: 0000D0
No fault code found.
Thanks in advance
Best Regards Jan Stoof
aangepast door Diver
Kort om mooi maar werkt dus niet meer op de oude manier naar alle updates.
Neen, maar het is wel nog mogelijk met de nieuwe versie VCDS. Gewoon een andere manier van instellen.
2 versies VCDS draaiende hebben is ook wat vind ik.
Atwoord op mn laatste mail van Dana.
Hi Jan,
Thanks for the update.  Glad to hear it worked out!
I replied to your thread in our forum:
http://forums.ross-tech.com/showthread.php?14471-Programming-folding-mirror-using-remote-(-car-key-)
Hopefully that adds clarity for the next person looking for "ENG109279-ENG99426-System_Parameter_0-System Parameter Byte8".
Best Regards,
Dana
Reactie van Dana op het Rosstech forum.
This is sorted per an email and a conversation here http://forum.vwpassat.nl/index.php?/...vcds/?p=811710
Using a current version of VCDS you should be able to make that modification to Byte 8 in Adp channel ENG109279 -or- ENG109297.
For the purpose of adding clarity for anyone using older instructions with one of our latest VCDS Release/Beta versions, this is an example from another vehicle that we had Adpmaps from:
1) VCDS Version: Release 17.8.0 (x64) Data version: 20170721 - DS276.2:
  • ENG109279-ENG99426-System_Parameter_0-System Parameter Byte8,95 ,16
  • ENG109297-ENG100496-System-Parameter Block-Bytes 1-20,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 E4 00 4C 00 ,242
2) VCDS Version: Beta 17.10.0 (x64) Data version: 20171026 - DS283.3:
  • ENG109279-System_Parameter_0,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 ,16
  • ENG109297-System-Parameter Block,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 E4 00 4C 00 0C 7A 0F 87 69 9E 00 00 05 08 0C 10 18 44 3F 62 9E 00 6E 3F 01 60 29 44 78 3C 64 55 46 46 4B 46 8A 88 9E 96 91 8C 07 8A FD 72 B5 34 00 53 50 19 07 B3 9B 61 73 2D 08 27 3C 86 14 28 0A 1D 14 0A 87 51 12 20 37 A0 B6 7D A0 3F AA 47 D9 22 19 0D 75 FF 32 75 C8 00 08 8C FF 2B 0E 80 10 04 9C 00 02 0D F2 0D 32 0C 0F 32 0A 0A 03 32 0A 03 20 20 20 0D 03 02 02 0D 0D 00 00 32 00 00 00 00 00 00 00 00 14 00 00 03 2A 9B 00 00 00 00 1E 28 37 46 5A 64 00 03 07 0A 0E 0F 28 1E 0A 75 75 DF 72 5B DF 72 5B 07 03 00 28 14 00 64 02 00 00 00 26 18 32 14 14 EA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 0F 74 E0 1E E4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,242
In this exact case "7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28" was present in the older VCDS version under channel ENG109297-ENG100496 but the same values are available in two channels (ENG109279 -and- ENG109297) using the current version.
