Wie o wie heeft een Premium carkit, RNS510 en ook nog VCDS om de code uit te lezen? Ik ben benieuwd wat voor code er staat en uiteraard ook welke telefoon je gebruikt.
De code die ik gebruik :
0020241
Modules die werken met deze code (voor zover ik weet)
5N0035730A
5N0035730B
5N0035730C <--- deze gebruik ik
Beetje uitleg :
??xxxxx
Undocumented – leave at 00
xx?xxxx
Language:
0: None
1: German
2: English
3: French
4: Spanish
5: Italian
6: Portuguese
7: Czech
xxx?xxx
Bluetooth Voice-Control Selection:
0: Bluetooth Voice-Control Audioset 1
1: Bluetooth Voice-Control Audioset 2
2: Bluetooth Voice-Control Audioset 3
3: Bluetooth Voice-Control ON
4: Bluetooth Voice-Control ON
5: Bluetooth Voice-Control ON
6: Bluetooth Voice-Control OFF
7: Bluetooth Voice-Control OFF
8: Bluetooth Voice-Control OFF
(I am unsure as to the functionality of this bit, possibly to do with enabling voice control via separate module e.g. RNS510. The CarSystem's [sic] documentation says to leave this bit on 3 whether using Bluetooth- or RNS-controlled voice activation, however I have mine set to 0, using Bluetooth-controlled voice activation.)
xxxx?xx
GSM Antenna Diagnosis/Phone Cradle Presence:
0: Antenna diagnosis ON/Phone cradle present
1: Antenna diagnosis ON/Phone cradle absent
2: Antenna diagnosis OFF/Phone cradle absent
3: Antenna diagnosis OFF/Phone cradle present
(If your aftermarket GSM antenna gives intermittent implausible signal faults due to some minor incompatibility with OEM antenna specification, disable antenna diagnosis to avoid fault codes.)
xxxxx?x
Voice Control Module Selection/Dash Keyboard Presence/Satnav Presence:
2: Bluetooth Voice Control/Dash Keyboard absent/Satnav absent
3: Bluetooth Voice Control/Dash Keyboard present/Satnav absent
4: Bluetooth Voice Control/Dash Keyboard absent/Satnav present
5: Bluetooth Voice Control/Dash Keyboard present/Satnav present
(Choose Bluetooth Voice Control to have Bluetooth module control voice activation, choose RNS voice control when e.g. RNS510 firmware 2660 or later is in use and the navigation unit handles voice activation.)
xxxxxx?
Line-out Diagnosis/Radio Mute Signal Activation/Overhead Buttons Presence
1: Line-out diagnosis ON/Mute Signal OFF/Overhead Buttons absent
2: Line-out diagnosis OFF/Mute Signal ON/Overhead Buttons absent
3: Line-out diagnosis ON/Mute Signal ON/Overhead Buttons absent
4: Line-out diagnosis OFF/Mute Signal OFF/Overhead Buttons present
5: Line-out diagnosis ON/Mute Signal OFF/Overhead Buttons present
6: Line-out diagnosis OFF/Mute Signal ON/Overhead Buttons present
7: Line-out diagnosis ON/Mute Signal ON/Overhead Buttons present
8: Line-out diagnosis OFF/Mute Signal OFF/Overhead Buttons absent
(I think Line-out diagnosis is similar to antenna diagnosis, if you get inconsistent fault codes with it enabled despite there being no real problem, turn it off. I believe Mute signal is a pin on the Bluetooth module which goes live during a call to activate phone mute on a non-OEM stereo.)
Ik ben inmiddels in staat om het hele zooitje op te pakken en zo in de klikko te frotten
Groovejunk
0020241
5N0035730A
5N0035730B
Beetje uitleg :
9 antwoorden op deze vraag
